  • 1 month later...
To capture a screenshot on your Tizen TV 4 and 6, you can use the built-in feature by pressing the "Home" button on your remote. Then, navigate to the "Settings" menu. From there, select "Support" and then "Device Care." Look for the "Screen Capture" option, and you should be able to take a screenshot.
