dnj Posted July 24, 2024 Report Posted July 24, 2024 I have a UE50TU7020 TV for which I would like to install a Flutter application, however as support for this was only introduced in Tizen 6.0, and the TV's seem to have shipped with Tizen 5.0, I wonder if they can be upgraded? And if so, to what version? The device is remote, so I can't just check for upgrades in the normal way. Before instructing others to do so I would like to find out if this device even supports 6.0+ Many thanks, Quote
Buymode Posted September 15, 2024 Report Posted September 15, 2024 You can check if your UE50TU7020 TV supports an upgrade to Tizen 6.0 or higher by visiting Samsung’s official support website or contacting their customer service. Since the device is remote, instructing someone to check for software updates directly on the TV might be the easiest way to confirm if an upgrade is available. Tizen 6.0 was introduced for newer models, so it's best to verify compatibility first. Quote
Joshua42 Posted September 27, 2024 Report Posted September 27, 2024 On 9/15/2024 at 11:18 AM, Buymode said: You can check if your UE50TU7020 TV supports an upgrade to Tizen 6.0 or higher by visiting Samsung’s official support website or contacting their customer service. Since the device is remote, instructing someone to check for software updates directly on the TV might be the easiest way to confirm if an upgrade is available. Tizen 6.0 was introduced for newer models, so it's best to verify compatibility first. To find out if your ''UE50TU7020 TV'' supports an update to ''Tizen 6.0'' or higher, go to Samsung's official support website. Alternatively, having someone check for software updates directly on the television can swiftly validate the availability of improvements. Because Tizen 6.0 is often seen on newer models, ensuring compatibility first is critical. For more assistance, please contact Samsung customer support (sources 15 and 16). Quote
Buymode Posted September 30, 2024 Report Posted September 30, 2024 On 9/27/2024 at 2:05 PM, Joshua42 said: To find out if your ''UE50TU7020 TV'' supports an update to ''Tizen 6.0'' or higher, go to Samsung's official support website. Alternatively, having someone check for software updates directly on the television can swiftly validate the availability of improvements. Because Tizen 6.0 is often seen on newer models, ensuring compatibility first is critical. For more assistance, please contact Samsung customer support (sources 15 and 16). Thanks for the advice! I’ll check the Samsung support website and see if someone can look for updates on the TV. I appreciate the help! Quote
