display orientation
By Sau
Hello,
I have Samsung TV (qe55q80datxxh) with Tizen OS and unfortunately it doesn’t find necessary apps on its store. I.e. App called “TV Zone” (https://tvzone.app) - it supports Tizen OS, but on Samsung store it is not visible. Is there any way to install this app in Samsung via store or like a third party app using usb stick (is it even possible?)?
Txanx!
We are pleased to announce the release of Tizen Studio version 6.0.
This release includes new features to enhance developer experience on Visual Studio Extension for Tizen, Visual Studio Code Extension for Tizen and Tizen Studio IDE.
Key features:
VS Code
Tizen activity bar, Device Monitoring and Welcome Page features have been added to enhance Tizen developer experience. TV Web development has been added along with the TV Web Simulator and Web Inspector features. SDK Installation Wizard is provided to easily setup Tizen SDK and Extensions. Unit Test, Code Coverage, ASAN, and LSAN Tools support has been added for Tizen Native Applications. Visual Studio (Windows)
Added Unit Test and Code Coverage support for Tizen Native Applications. Added ASAN and LSAN tools support for Tizen Native Applications. Added context menu option named Install Tizen Application to install application directly on a target device.
Tizen Studio
Added Tizen 9.0 profile and deprecated all Tizen profiles below 6.0. Tizen Issue Reporter added in SDK and Baseline tools. Tizen Studio and Tizen tools are now supported on Windows 11 OS.
For more information about the new features and bug fixes, check Release Notes.
To download Tizen Studio, visit https://developer.tizen.org/development/tizen-studio/download.
By adem377
Hello everyone, I hope you're doing well. I have Tizen TV 4 and 6 devices, and I would like to know how I can capture a screenshot within the Tizen system on these devices.
By jerry
I have created two hosted web apps on Tizen. One serves as a launcher app, and the other functions as a receiver app, responsible for displaying the page initiated by the launcher. How can I achieve this? Any suggestions?
(Note: Both are hosted Tizen apps.)
By Blackbird
I plugged a USB microphone into TV to record external audio. In my .NET app I can detect it with AudioManager.GetConnectedDevices(). To record audio I set the privileges (microphone) and follow the instructions here:
https://docs.tizen.org/application/dotnet/guides/multimedia/raw-audio/
I tried both methods sync and asysnc:
https://docs.tizen.org/application/dotnet/api/TizenFX/API11/api/Tizen.Multimedia.AudioCapture.html
https://docs.tizen.org/application/dotnet/api/TizenFX/API11/api/Tizen.Multimedia.AsyncAudioCapture.html
I instantiate AudioCapture or AsyncAudioCapture objects and when I invoke the Prepare() method the app crashes without any exception or error message.
Simplified code snippet:
AudioCapture audioCapture = new AudioCapture(44100, AudioChannel.Mono, AudioSampleType.S16Le); int bufferSize = audioCapture.GetBufferSize(); const int RecordingSec = 1; bufferSize *= 10 * RecordingSec; audioCapture.Prepare(); // THIS LINE CRASHES byte[] buffer = audioCapture.Read(bufferSize); The same result is on two different models (Tizen 6.0 and Tizen 6.5).
How can I record audio from microphone on Tizen TV? What am I missing?
