With the emergence of social video platforms and wide access to high-resolution cameras, it’s safe to say we’re living in the golden age of accessible, high-quality video content. As more content creators join these spaces and competition increases, many are focusing on making the best quality videos possible to stand out. More than ever, creators are carefully choosing their PC monitors based on image quality and color accuracy to ensure their creations meet their audiences’ expectations.
Samsung Electronics recently unveiled the ViewFinity S8 (Model Name: S80PB), a high-resolution monitor adopting a wide range of features for creative professionals who rely on devices, such as monitors and mobile devices, to create new content. It’s a new benchmark for high-resolution monitors. Here, Samsung Newsroom unboxes the ViewFinity S8 to see how this new product can help emerging creators.
Power and Connect Devices Clutter-Free With USB Type-C
After opening the box, you can see that the package is comprised of the monitor, HDMI cable, USB Type-C cable and the power cable.1 The simplicity of package is made possible thanks to the USB Type-C cable that easily connects the monitor to various devices without additional cables.
Fewer cables on the desk are what creators want as they use multiple devices, including a drawing tablet. A single USB Type-C connection not only displays the external devices to the monitor but provides fast charging with up to 90W power and 10Gbps data transfers without a separate power cable. Even with laptop without LAN port, you can use Ethernet2 just by connecting wired LAN port to monitor instead, which transmit LAN signal to connected laptop.
Installation of the ViewFinity S8 is simple. First, connect the stand’s neck to its base and fasten the bolts. The work is already halfway done. Next, connect the assembled base to the monitor by pushing down until there is a click.
Once the power is on, the first thing you will notice immediately is the picture quality that stands out. Its UHD resolution (3840 X 2160) has four times more pixels than Full HD, revealing hidden details with greater depth. ViewFinity S8 offers a wide color gamut up to 98% of DCI-P3 for lifelike color. In addition, its 178° wide viewing angle delivers brilliant color and punchy images from various angles.
Contrast is as important as color accuracy, especially for videos, since it determines the content quality and realism. Specifically, ultra-fine contrast is critical in expressing scenes with a dark background and bright lights like a starry night sky. ViewFinity S8 meets the standard of Video Electronics Standards Association (VESA) DisplayHDR™ 600, making bright areas brighter and dark areas darker, presenting true-to-life images.3
The Best Content Creation Environment With the Matte Display and Ergonomic Stand
Compared to conventional,4 glossy monitors, ViewFinity S8 minimizes glare and reflection. As the world’s first UL-verified Glare Free monitor, Matte Display is applied on the top of the panel, reducing distraction caused by glare.
Many creators use a monitor hood to prevent glare caused by indoor lighting and sunlight. To recreate this environment, we tried installing a monitor hood, and the process was not easy. The hood is heavy, has difficult screen positioning and it costs you extra money.
ViewFinity S8 dispels such concerns by adopting the Matte Display, which reduces light reflection and allows users to view images more clearly without an additional attachment. This also means you can use your desk space more efficiently.
▲ (left) 2021 ViewFinity S70A. (right) 2022 ViewFinity S80PB
ViewFinity S8 also introduces a whole new world of ‘deskterior,’ a portmanteau of ‘desk’ and ‘interior,’ allowing you to transform your desk into a perfectly customized working environment. Setting the monitor on a different spot or adding a décor item will not only boost your mood but also improve work productivity.
You can notice the true value of ViewFinity S8 when creating vertical content. Of course, there are monitors that can pivot, but often the rotation forces you to reinstall the monitor hood. In contrast, ViewFinity S8 users can freely switch the monitor horizontal or vertical, allowing you to create and edit vertical videos at the original ratio. You can also have the best view for vertical content like a long-scrolled text or digital comics.
Furthermore, ViewFinity S8 features a height-adjustable stand that can tilt and swivel. The monitor can also be installed on a wall. ViewFinity S8 offers the most optimal angle to give you the best working space and enhance productivity without having to adjust the height of your desk or chair.
Easy On the Eyes With Intelligent Eye Care
Working at night and for hours at a time, both can lead to eye strain. ViewFinity S8’s Intelligent Eye Care such as Adaptive Picture, Eye Saver Mode and Flicker Free features can help alleviate eye strain.
Adaptive Picture is a useful feature for content creators who work at night. Adaptive Picture, which automatically adjusts brightness and color temperature depending on the surroundings, and the ViewFinity S8 immediately optimizes picture quality. If you want to minimize the stress on your eyes, the Eye Saver Mode smartly reduces blue light emissions and the Flicker Free helps protect your eyes from flickering screens.
Evolution Towards Sustainability
ViewFinity S8 is also built with the environment in mind. Samsung used recycled ocean-bound plastics in the rear covers of ViewFinity S8. Samsung’s Eco Savings Plus technology reduces power consumption by utilizing its built-in photo resistor to adjust optimal brightness and color temperature. You can reduce the power consumption up to 10% by setting the Eco Savings Plus Mode. Samsung ViewFinity S8 is recognized industry-wide with EnergyStar, TCO5 and EPEAT sustainability certifications.
Monitors are one of the most important gadgets for content creators to pay more attention to the details in their work. To elevate the quality of their content, first they must create the optimal working space that is distraction-free, ergonomic and equipped with devices that meet the demands. The Samsung ViewFinity S8 is the perfect fit that will help creators unleash their creativity and full potential.
* Some of the images shown are for illustration purposes only.
1 Accessories may vary by country or region.
2 Requires ViewFinity to be plugged into internet modem via a LAN cable. Internet speeds vary by provider and region.
3 It refers to the 32-inch model. 27-inch model supports VESA Display HDR 400.
4 Previous Samsung monitors without the Matte Display (e.g. 2021 ViewFinity S80A).
5 TCO Certified, generation 9. TCO Certified is a global sustainability certification for IT products, available for computers, mobile devices, display products and data center products. Criteria cover both social and environmental sustainability and enable circular solutions. Compliance with criteria is independently verified. TCO Certified is a third-party certification in accordance with ISO 14024.
      Samsung Electronics and Logitech celebrate five years of partnership in video conferencing, combining their industry-leading solutions to enhance workplace collaboration and productivity. The integration of Samsung high-definition displays with Logitech’s video conferencing solutions creates immersive, connected experiences ready to meet the needs of today’s employees.
      ▲ Samsung Electronics’ high-definition displays integrated with Logitech’s conference cameras, webcams and audio systems enable seamless collaboration for hybrid teams.
      With the rise of flexible work environments, organizations require meeting spaces equipped with advanced video conferencing technology to enable seamless collaboration for distributed teams. Businesses can now leverage Samsung’s high-definition displays with Logitech’s conference cameras, webcams and audio systems to achieve crystal-clear video and sound, helping remote and in-person participants feel like they are in the same room. Samsung Interactive Displays also enable teams to connect, share ideas and whiteboard on a single screen. These meeting solutions make every participant feel equally engaged regardless of location.
      ▲ The Samsung Interactive Display is a powerhouse tool for team collaboration.
      “Samsung and Logitech products empower teams to work better together,” said Sukhmani Mohta, Chief Marketing Officer, Display Division, Samsung Electronics America. “With purpose-built solutions that integrate effortlessly into today’s workplaces, we’re helping organizations to reimagine collaboration, spark creativity and achieve greater productivity. We are shaping the future of work by fostering deeper connections and creating fulfilling experiences for teams.”
      ▲ Samsung and Logitech solutions support dynamic and flexible workspaces for today’s employees.
      Traditional workspaces are evolving into more dynamic and flexible environments. “Hot desking,” where employees can choose their workstation for a given day rather than having assigned desks, is supported by Samsung monitors that work seamlessly with Logi Dock Flex. This allows employees to quickly plug into any available desk and start working immediately. This streamlined experience minimizes technical challenges, reduces stress and promotes productivity in an adaptable workplace.
      “Our partnership with Samsung is founded on shared values such as drive for innovation and focus on customer needs,” said Sudeep Trivedi, Head of Alliances and Go-to-Market, Logitech. “We collaborate to address challenges and anticipate the evolving needs of almost every industry. We’re eager to continue driving innovation, anticipating and fulfilling the needs of our customers in the years ahead.”
      ▲ Samsung and Logitech remain committed to building sustainable design into every product and empowering organizations to manage their energy consumption.
      Samsung and Logitech also share a mutual commitment to building environmental sustainability into every product. Both companies have created solutions that automatically go into standby mode or turn off when not in use to help reduce energy consumption. Device management systems like Samsung SmartThings Pro offer remote control and monitoring of the performance and environmental impact of connected office technologies. Logitech’s ambitious climate strategy includes Design for Sustainability principles that have resulted in three out of four products using next-life, recycled plastics, 66% of products carbon labeled and 94% of the company’s electricity footprint coming from direct and indirect renewable electricity purchases.
      ▲ Samsung and Logitech help businesses to minimize technical challenges and promote productivity in adaptable workplaces.
      At the Logitech Experience Center in San Jose, California, businesses can view Samsung and Logitech’s joint solutions in a realistic work environment. The collaborative space, which serves as both a fully functioning office for Logitech employees and a showroom for customers, demonstrates how these innovations can unlock new possibilities for modern workplaces.
      To learn more about Samsung and Logitech’s immersive, integrated workplace solutions, read the full case study on their collaboration.
      The future of displays is here! Earlier this month at ISE 2025, Samsung Electronics showed off its latest commercial display innovations. From the energy-efficient Samsung Color E-Paper and AI-powered Interactive Display to Transparent MICRO LED and HoloDisplay, the company captivated attendees with its expansive lineup of display solutions and their limitless applications.
      Check out the videos below for a closer look at how Samsung is transforming the industry in 2025.
      Samsung Color E-Paper: A Signage Solution Ready To Replace Traditional Posters in Storefronts
      Samsung Color E-Paper is a paper-thin, ultra-low power and lightweight display serves as an energy efficient alternative to traditional analog and paper-based promotional materials. This solution consumes near-zero power while displaying static images by leveraging ambient light to illuminate the content. A dedicated app and Samsung VXT makes it easy to manage.
      AI-Powered Interactive Display: A Smarter, more connected Screen for Classrooms
      The Samsung’s 2025 Interactive Display is redefining the classroom with AI-powered learning tools that make education smarter and more connected. From instant answers with Circle to Search to AI-generated lesson recaps and real-time transcriptions, students and educators get seamless AI support — right on the screen.
      2025 Hotel TV Lineup: An Entertainment Experience Tailored to Every Guest
      Samsung’s latest hospitality display solutions eliminate the need for  extra cables or a complicated setup. Guests can instantly stream content from their devices with AirPlay and Google Cast. With SmartThings Pro, they can enjoy seamless in-room control, while LYNK Cloud enables easy access to dining, concierge services and check-out — right from the TV.
      The Wall IWC: Uninterrupted Display for Command and Control in Mission-Critical Environments
      In mission-critical environments like command-and-control centers, every second counts. Incorporating Samsung’s MICRO LED technology, The Wall IWC ensures uninterrupted operation with seamless visuals and fast, modular maintenance — delivering clarity and reliability when it matters most.
      The Wall IVC: An Advanced Display Optimized for Content Creation in Corporate Broadcast Studios
      The Wall for Virtual Production (IVC model) is revolutionizing corporate broadcasting. At ISE 2025, Samsung unveiled the first-ever broadcasting bundle with ARRI and Realtime Department — designed for seamless workflows, stunning MICRO LED visuals and effortless content creation.
      Transparent MICRO LED and HoloDisplay: Cutting-Edge Display Solutions for Unforgettable Museum Exhibits
      These two futuristic solutions captivate and engage visitors in new ways. The Transparent MICRO LED can transform exhibits into seamless, bezel-less interactive experiences with 360-degree viewing experiences by showing content on the showcase. The HoloDisplay immerses viewers by projecting sharp and high-contrast floating 3-dimensional images.
      Samsung Electronics received a total of 12 awards, including five Best of Show awards at ISE 2025, demonstrating its industry dominance. While Samsung continues to push the boundaries for commercial display, the future is already here with its 2025 lineup. For more information, visit: http://smsng.co/B2Bsolutions.
      * Availability and features may vary by model and are subject to change without prior notice.
      Samsung Electronics held its First Look 2025 event on January 5 in Las Vegas ahead of the opening of the CES 2025 exhibition. The company unveiled an array of innovative technologies and introduced Vision AI, a new path for AI screens and the display industry.
      At the event, Samsung showcased its latest lineup of ultra-large TVs including the 2025 Neo QLED 8K, the 85-inch Neo QLED 4K and the 83-inch OLED. Other highlights from the First Look 2025 showroom included The Premiere 5, an interactive display with triple laser technology designed for intuitive operation, and the MICRO LED Beauty Mirror, a display that analyzes users’ skin conditions to offer personalized beauty solutions.
      “TVs in the AI era will become life companions and provide new user experiences,” said SW Yong, President and Head of Video Display (VD) Business at Samsung Electronics, during his opening speech.
      Watch the video below to explore Samsung’s latest advancements in display technology at the First Look 2025.
    • By adem377
      Hello everyone, I hope you're doing well. I have Tizen TV 4 and 6 devices, and I would like to know how I can capture a screenshot within the Tizen system on these devices.
    • By Mahesh Gadhe
      <article>
              <div><img id="imageTag" src=""></div>
              <div><video id="videoTag" onended="onVideoEnded();" src=""></video></div>
              <!--<div id="YoutubePlayer" width="600" height="400" src="" frameborder="0" sandbox="allow-same-origin allow-scripts allow-popups allow-forms allow-top-navigation" style="z-index: 1;"></div>-->
              <div style="position:fixed; top:50%; left:50%; transform:translate(-50%, -50%); z-index:999;">
              <div id="YoutubePlayer" style="width:600px; height:400px;"></div>
          </div>
          </article>
      As to play the youtube video we need to use the youtube iframe, we are facing challenge here. When the youtube video plays on the TV, we lose control over app and hence next video as per CMS does not play. Same happens vice versa i.e when a video from CMS starts playing we are not able to play youtube video if it is next in the list.
