Hi, i have samsung profesional display QH55R with Tizen 4. The software is up-to-date 2350.
I want to display my own web application or just a movie. I don't want to use the management panel from samsung.
Display is connected to my wi-fi network. I instal tizen studio,  create new web project tv-samsung-6.5 (template -> tv-samsung-6.5 ->web application -> Basic Project) , change project required version 4.0, create Samsung author  certificate, create distributor certificate, instal distributor cetrificate on Samsung Display, connect to Display in Device Manager.
I can run app on Display from tizen studio by Debug mode.  I build signed package and i have .wgt file.
Now i have problem.
In device manager when i try install application i have error:  org.tizen.sdblib.exception.SdbCommandRejecteException: closed.
I put .wgt file on web serwer, and set in Samsung Display to run from url: "http://........ /file.wgt" and I have error too.
I try to run some webpage from url, also does not work. (I can manually open webbrowser and open webpage but this is not the effect I mean).
I cant find any information, how can i always on start:
- run my tizen app on display,
- run wideo from url/local file
- open url website
I will be grateful for help or link to documentation.
      “Samsung’s QLED technology played a crucial role in bringing quantum dots to the level of recognition needed for the Nobel Prize in Chemistry.”
      Quantum dots have been at the forefront of display innovation over the past decade, delivering some of the most accurate color reproduction among existing materials. In 2015, Samsung Electronics paved the way for the commercialization of quantum dots with the launch of SUHD TVs — a breakthrough that moved beyond the use of cadmium (Cd), a heavy metal traditionally utilized in quantum dot synthesis, by introducing the world’s first no-cadmium quantum dot technology.
      The academic world took notice. The successful commercialization of cadmium-free quantum dot TVs not only set a new direction for research and development but also played a pivotal role in the awarding of the 2023 Nobel Prize in Chemistry for the discovery and synthesis of quantum dots.
      Following Part 1, Samsung Newsroom uncovers how Samsung has contributed to academia through groundbreaking advances in material innovation.
      ▲ (From left) Taeghwan Hyeon, Doh Chang Lee and Sanghyun Sohn
      Why Cadmium Was the Starting Point for Quantum Dot Research
      “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Quantum dots began attracting scientific interest in the 1980s when Aleksey Yekimov, former Chief Scientist at Nanocrystals Technology Inc., and Louis E. Brus, a professor emeritus in the Department of Chemistry at Columbia University, each published their researches on the quantum confinement effect and the size-dependent optical properties of quantum dots.
      Momentum accelerated in 1993 when Moungi Bawendi, a professor in the Department of Chemistry at the Massachusetts Institute of Technology (MIT), developed a reliable method for synthesizing quantum dots. In 2001, Taeghwan Hyeon, a distinguished professor in the Department of Chemical and Biological Engineering at Seoul National University (SNU), invented the “heat-up process” — a technique for producing uniform nanoparticles without the need for size-selective separation. In 2004, Hyeon published a scalable production method in the academic journal Nature Materials — a discovery widely regarded as a potential game changer in the industry.
      However, these efforts did not immediately lead to commercialization. At the time, quantum dots relied heavily on cadmium(Cd) as a core material — a substance known to be harmful to humans and designated as a restricted material under the European Union’s Restriction of Hazardous Substances (RoHS) Directive.
      “Currently, the only materials capable of reliably producing quantum dots are cadmium selenide (CdSe) and indium phosphide (InP),” explained Hyeon. “Cadmium selenide, the conventional quantum dot material, is a compound of group II and group VI elements, while indium phosphide is formed from group III and group V elements. Synthesizing quantum dots from group II and VI elements is relatively straightforward, but combining group III and V elements is chemically much more complex.”
      ▲ A comparison of cadmium-based quantum dots with ionic bonds and indium-based quantum dots with covalent bonds
      Cadmium, an element with two valence electrons, forms strong ionic bonds1 with elements like selenium (Se), sulfur (S) and tellurium (Te) — each of which has six valence electrons. These combinations result in stable semiconductors, known as II–VI semiconductors, materials that have long been favored in research for their ability to produce high-quality nanocrystals even at relatively low temperatures. As a result, the use of cadmium in quantum dot synthesis was considered an academic standard for many years.
      In contrast, indium (In) — an alternative to cadmium with three valence electrons — forms covalent bonds2 with elements such as phosphorus (P), which has five valence electrons. Covalent bonds are generally less stable than ionic bonds and have a directional nature, increasing the likelihood of defects during nanocrystal synthesis. These characteristics have made indium a challenging material to work with in both research and mass production.
      “It is difficult to achieve high crystallinity in quantum dots made from indium phosphide,” Lee noted. “A complex and demanding synthesis process is required to meet the quality standards necessary for commercialization.”
      No Compromise – From Breakthrough to Mass Production
      “There is simply no room for compromise when it comes to consumer safety.”
      Samsung, however, took a different approach.
      “We had been researching and developing quantum dot technology since 2001,” said Sanghyun Sohn, Head of Advanced Display Lab, Visual Display (VD) Business at Samsung Electronics. “But early on, we determined that cadmium — which is harmful to the human body — was not suitable for commercialization. While regulations in some countries technically allow up to 100 parts per million (ppm) of cadmium in electronic products, Samsung adopted a zero-cadmium policy from the start. No cadmium, no compromise — that was our strategy. There is simply no room for compromise when it comes to consumer safety.”
      Samsung’s long-standing commitment to its principle of “No Compromise on Safety” came to the forefront in 2014 when the company successfully developed the world’s first no-cadmium quantum dot material. To ensure both durability and image quality, Samsung introduced a triple-layer protective coating technology that shields indium phosphide nanoparticles from external factors such as oxygen and light. The following year, Samsung launched the world’s first commercial SUHD TV with no-cadmium quantum dots — a paradigm shift in the display industry and the culmination of research efforts that began in the early 2000s.
      “Indium phosphide-based quantum dots are inherently unstable and more difficult to synthesize compared to their cadmium-based counterparts, initially achieving only about 80% of the performance of cadmium-based quantum dots,” said Sohn. “However, through an intensive development process at the Samsung Advanced Institute of Technology (SAIT), we successfully raised performance to 100% and ensured reliability for more than 10 years.”
      ▲ The three components of quantum dots
      Quantum dots found in Samsung QLEDs are composed of three key components — a core, where light is emitted; a shell, which protects the core and stabilizes its structure; and a ligand, a polymer coating that enhances oxidation stability outside the shell. The essence of quantum dot technology lies in the seamless integration of these three elements, an advanced industrial process that spans from material acquisition and synthesis to mass production and the filing of numerous patents.
      “None of the three components — core, shell or ligand can be overlooked,” added Lee. “Samsung’s technology for indium phosphide synthesis is outstanding.”
      “Developing a technology in the lab is a challenge in itself, but commercialization requires an entirely different level of effort to ensure product stability and consistent color quality,” said Hyeon. “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Setting the Quantum Dot Standard
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs.”
      The optical properties of quantum dots are being applied to a wide range of fields, including solar cells, medicine and quantum computing. However, the quantum dot display remains the most actively researched and widely commercialized application to date — with Samsung emerging as a pioneer.
      Building on years of foundational research and the introduction of its SUHD TVs, Samsung launched its QLED TVs in 2017 and set a new standard for premium displays. In 2022, the company pushed innovation further with the debut of QD-OLED TVs — the world’s first display to combine quantum dots with an OLED structure.
      ▲ A comparison of LCD, QLED and QD-OLED structures
      QD-OLED is a next-generation display technology that integrates quantum dots into the self-emissive structure of OLED. This approach enables faster response times, deeper blacks and higher contrast ratios. Samsung’s QD-OLED was awarded Display of the Year in 2023 by the Society for Information Display (SID), the world’s largest organization dedicated to display technologies.
      “Samsung has not only led the market with its indium phosphide-based quantum dot TVs but also remains the only company to have successfully integrated and commercialized quantum dots in OLEDs,” said Sohn. “By leveraging our leadership in quantum dot technology, we will continue to lead the future of display innovation.”
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs,” said Doh Chang Lee, a professor in the Department of Chemical and Biomolecular Engineering at the Korea Advanced Institute of Science and Technology (KAIST). “Since its launch, discussions have increasingly focused on practical applications rather than the materials themselves, reflecting the potential for real-world implementation through display technologies.”
      “There have been many attempts to apply quantum dots in various fields including photocatalysis,” he added. “But these efforts remain in the early stages compared to their use in displays.”
      Hyeon also noted that the successful commercialization of Samsung’s quantum dot TVs helped pave the way for Bawendi, Brus and Yekimov to receive the 2023 Nobel Prize in Chemistry.
      “One of the most important criteria for the Nobel Prize is the extent to which a technology has contributed to humanity through commercialization,” he said. “Samsung’s QLED represents one of the most significant achievements in nanotechnology. Without its commercialization, it would have been difficult for quantum dots to earn Nobel recognition.”
      Samsung’s Vision for Tomorrow’s Displays
      Since the launch of its QLED TVs, Samsung has accelerated the growth of quantum dot technology in both industry and academia. When asked about the future of quantum dot displays, the experts shared their insights on what lies ahead.
      “As a next-generation technology, we are currently exploring self-emissive quantum dots,” said Sohn. “Until now, quantum dots have relied on external light source to express red and green. Going forward, we aim to develop quantum dots that emit light independently through electroluminescence — producing all three primary colors by injecting electrical energy. We are also working on the development of blue quantum dots.”
      “As electroluminescent materials make it possible to reduce the size of device components, we’ll be able to achieve the high resolution, efficiency and brightness required for virtual and augmented reality applications,” said Lee, predicting a major transformation in the future of displays.
      “A good display is one the viewer doesn’t even recognize as a display,” said Sohn. “The ultimate goal is to deliver an experience that feels indistinguishable from reality. As a leader in quantum dot display innovation, we will proudly continue to move forward.”
      With its continued leadership and bold technological vision, Samsung is shaping the future of displays and rewriting what’s possible with quantum dots.
      1 An ionic bond is a chemical bond formed when electrons are transferred between atoms, creating ions that are held together by electrical attraction.
      2 A covalent bond is a chemical bond in which two atoms share electrons.
      ▲ Samsung Onyx was the highlight of the company’s exhibition at CinemaCon 2025.
      Samsung Electronics reaffirmed its leadership as a pioneer in cinema LED technology at CinemaCon 2025, the ‘largest and most important gathering of movie theater owners from around the world,’ held in Las Vegas, Nevada from March 31 to April 3. At this event, Samsung unveiled the latest Samsung Onyx cinema LED screen with its unmatched picture quality, industry-leading reliability, and expanded scalability to meet the evolving needs of theaters worldwide.
      With nearly 6,000 industry professionals from more than 80 countries coming together to celebrate the moviegoing experience, CinemaCon is essential for companies that serve the cinema industry. Samsung invited industry professionals to its immersive booth to discover the latest in premium theater technology and watch films from leading studios.
      ▲ Attendees arriving at CinemaCon 2025 at Caesars Palace, Las Vegas; Inside Out 2 displayed on Samsung’s QMD supersized 105” signage
      Redefining Luxury Theater Experiences with Samsung Onyx
      At the booth, theater owners and industry leaders had a chance to experience films, including Elio (2025) on the new Samsung Onyx screen, showing attendees a cinematic experience that is unmatched with true black levels, infinite contrast ratio, and exceptional color accuracy.
      ▲ Pixar’s Elio screened on Samsung Onyx at CinemaCon 2025
      The new Samsung Onyx screen supports frames up to 4K 120Hz1 to deliver ultra-smooth motion and razor-sharp quality that brings out more details on screens. Further, Onyx can reach peak brightness levels of 300 nits (86.7fL), six times brighter than traditional cinema standards, which means the brightest details on the screen remain visible to the audience.2
      While traditional projectors often appear dim in larger theaters and struggle with washed-out colors in bright scenes, Samsung Onyx maintains exceptional brightness to reveal rich details in shadows, intense highlights and stunning color accuracy across the spectrum.
      “The color and vibrancy are very rich,” said Cynthia Lusk, Director of Creative Film Services and International Production at Pixar Studios. “On the Onyx display, there are details of the characters shown that I haven’t seen on a screen before.”
      ▲ A colorful scene from Pixar’s Inside Out 2 during a screening on Samsung Onyx at CinemaCon
      This year’s Onyx offers theater owners four standard sizes3 – 5 meters (16 feet), 10 meters (33 feet), 14 meters (46 feet), and 20 meters (66 feet) – with additional flexible scaling options to accommodate a variety of theater dimensions.
      Cannon Beach, a mixed use development blending lifestyle and adrenaline in Mesa, Arizona, will be the first location in the United States to introduce the latest generation of Samsung Onyx in its movie theater, LVL 11 Entertainment.
      ▲ Opening in Fall 2025, LVL 11 Entertainment at Cannon Beach will be the first cinema in the United States to introduce the latest generation of Samsung Onyx in an auditorium with a balcony, creating a unique viewing experience built around the Cinema LED screen.
      “We chose to partner with Samsung because its commitment to innovation and cutting-edge technology aligns perfectly with our vision for LVL 11 Entertainment. By premiering the Samsung Onyx Cinema LED Screen in Arizona, we will be offering an entirely new experience, not just a movie,” said Adam Saks, Chief Operating Officer, LVL 11 Entertainment. “Samsung’s ability to push the boundaries of entertainment technology ensures that LVL 11 at Cannon Beach remains at the forefront of the industry.”
      Digitizing In-Theater Movie Promotion with Color E-Paper
      ▲ Floor maps showcased on Samsung Color E-Paper displayed at the Samsung booth, demonstrating the screen’s paper-like display and slim depth.
      Outside the theater, Samsung introduced new digital signage to help theater owners transform the entire moviegoing experience.
      Samsung Color E-Paper is an ultra-low power, lightweight and slim display that can replace traditional analog and paper-based promotions while delivering the high visibility and functionality. A dedicated mobile app allows theater owners to seamlessly operate the display remotely, and schedule wake-up and sleep times. With Samsung VXT managing the content of Color E-Paper, updating is simplified as theaters change displays to promote the next upcoming blockbuster.
      Immersive Theater Lobbies with Cinematically Designed Signage
      ▲ Information about Elio(Pixar, 2025) displayed on Samsung’s QMD supersized 105” signage with a Samsung kiosk
      Samsung’s QMD series 105-inch supersized screen delivers a unique viewing experience, immersing moviegoers with a large screen before they step into the auditorium. Featuring a cinematic 21:9 ratio, the QMD is designed to captivate the audience, enhance brand visibility and enhance the overall theater environment.
      Transforming Menu Boards with Appetizing Visuals
      ▲ Samsung QMC signage displayed at CinemaCon, showcasing its vivid colors and dynamic content to captivate attendees before they enter the Onyx theater
      Samsung QMC signage will immediately draw movieogers upon arrival, showcasing one billion shades of color and allowing theaters to display their food and beverage offerings in a more engaging manner. The QMC’s slim profile enables theaters to optimize their space, seamlessly blending the display into any theater environment.
      ▲ CinemaCon 2025 official poster contest winners
      Samsung’s participation at CinemaCon underscores its pioneering excellence and continued legacy in cinema LED display. Industry experts, theater owners, and studios witnessed how Samsung is ushering in the future of cinematic innovation and leadership to build excitement for the future of films.
      1 Based on the screen’s internal data bandwidth. Actual frame rates may vary depending on the connected IMB. 4K resolution support applies to Onyx’s four standard sizes.
      2 Peak brightness supported when using DCI-HDR supported IMB.
      3 All measurements in meters and feet refer to screen width, while all measurements in inches denote diagonal; The 10-meter Onyx screen is now available for order, with other models arriving in a phased rollout.
      ▲ Samsung Neo QLED 4K TV (QN85F)
      Samsung Electronics today announced that its smart TVs and monitors will now support Netflix shows and movies in HDR10+.1 With HDR10+, viewers can enjoy richer contrast, deeper colors and stunning visual depth, making their favorite Netflix titles more immersive than ever.
      “HDR10+ enhances the way we watch content, delivering deeper contrast and more vibrant colors for a truly cinematic experience,” said Taeyong Son, Executive Vice President of Visual Display Business at Samsung Electronics. “We are excited to bring this technology to Netflix’s 300 million plus members and will continue collaborating with various partners to expand HDR10+ support across our product lineup and the broader streaming ecosystem.”
      HDR10+ is a next-generation high dynamic range (HDR) technology pioneered by Samsung, designed to optimize picture quality scene by scene. By dynamically adjusting brightness and contrast levels, HDR10+ ensures that each frame is displayed with exceptional clarity and detail, staying true to the creator’s intent.
      With this integration, viewers can experience enhanced realism and depth across a growing library of HDR10+ content, making every scene feel more lifelike. HDR10+ content on Netflix will be accessible on 2025 Samsung Neo QLED, OLED and Lifestyle TVs — as well as 2025 and 2024 monitor models — with support for additional models in the future.
      This launch marks a significant step in expanding HDR10+ content, bringing enhanced picture quality to more viewers. In addition to Netflix, Samsung is actively working with a growing network of industry partners to further extend HDR10+ support. For more information on Samsung TV, please visit www.samsung.com.
      1 Samsung co-established HDR10+ Technologies LLC in 2018 to provide a royalty-free, open dynamic metadata standard in the industry.
      Samsung Electronics today announced the latest Onyx (ICD model) cinema LED screen at CinemaCon 2025, marking a new era for cinema display technology. Building on its legacy as a cinema LED pioneer, which began in 2017, Samsung is setting new standards with unmatched picture quality, industry-leading reliability and expanded screen scalability to meet the evolving needs of theaters worldwide.
      “The cinema industry is shifting its focus towards delivering a more immersive and visually captivating experience,” said Hoon Chung, Executive Vice President of Visual Display Business at Samsung Electronics. “With Onyx, Samsung delivers not only the highest-quality visuals but also the flexibility that allows theaters to redefine the movie-going experience and cater to evolving audience expectations.”
      Brighter, Bolder and More Immersive: The Future of Cinema Is Here
      As the world’s first DCI-certified1 cinema LED display, Samsung Onyx delivers an unparalleled cinematic experience with true black levels, infinite contrast ratio and exceptional color accuracy. The screen is capable of supporting frame rates up to 4K 120Hz,2 delivering ultra-smooth motion and razor-sharp details.
      Every auditorium has unique dimensions, and screen size requirements vary from theater to theater. To accommodate this, Onyx offers four standard sizes3 and additional flexible scaling options, allowing theaters to maximize their available space and present films in the largest possible format without compromising image quality:
      5 meters (16ft) — Ideal for boutique and smaller-format theaters (Pixel pitch: 1.25mm) 10 meters (33ft) — The industry standard for premium cinemas (Pixel pitch: 2.5mm) 14 meters (46ft) — A versatile format that delivers an impressive, large-scale cinematic experience (Pixel pitch: 3.3mm) 20 meters (66ft) — A large-format solution for premium auditoriums (Pixel pitch: 5.0mm)
      Samsung Onyx cinema LED screens natively support both scope (2.39:1) and flat (1.85:1) aspect ratios, ensuring films are displayed in their intended formats without the need for additional adjustments. When scaling beyond standard sizes, Onyx maintains both aspect ratios while maximizing the screen size, allowing content to expand proportionally without distortion.
      Unlike traditional projectors, which can appear dim in larger theaters and struggle with washed-out colors in bright scenes, Onyx’s enhanced brightness ensures richer details in shadows, more intense highlights and superior color accuracy across the entire spectrum. Powered by Samsung’s HDR technology, Onyx reaches peak brightness levels of 300 nits (87.6fL) — six times brighter than conventional cinema standards — allowing even the brightest details to remain clear and visible.4 As a result, high-brightness scenes retain their full impact, rather than appearing washed out or overexposed.
      With its industry-leading brightness and precision, Onyx enables clear and vivid playback even in brightly lit environments, making it ideal for alternative content such as live sports, concerts, gaming events and corporate presentations. This allows theaters to deliver a premium viewing experience beyond traditional movie screenings.
      Built for Reliability and Seamless Integration
      Onyx is built for long-term performance, offering the industry’s first and longest 10-years warranty for cinema LED,5 setting a new benchmark for reliability in cinema display technology. This extended coverage helps reduce total cost of ownership and ensures a future-proof investment for theater owners.
      To maintain optimal picture quality, Samsung provides an auto calibration solution that enables theaters to easily calibrate their screens during installation and routine maintenance.
      Designed for seamless integration, Onyx is compatible with both Dolby and GDC media servers, making it easier for theaters to transition from traditional projection systems. Because of this, theater networks can enjoy seamless content playback and efficient management.
      Onyx is fully compatible with leading cinema audio solutions, including Dolby Atmos, Meyer Sound, QSC and custom-designed sound systems, providing theaters with the flexibility to customize their sound experience to meet their specific needs. For theaters using HARMAN’s JBL surround sound technology, Onyx also offers seamless integration to ensure optimized audio performance.
      A Proven Legacy With Global Recognition
      Samsung Onyx is one of the most widely adopted cinema LED screens in theaters worldwide — setting a new industry standard for premium cinema display technology. As it expands its presence, Onyx continues to showcase its unmatched reliability, versatility and ability to elevate the cinematic experience.
      One of the most recent installations is at Pathé Palace in Paris, where Onyx was selected to enhance the premium viewing experience in one of the world’s most visually stunning cinemas.
      “At Pathé, we are committed to delivering the highest-quality cinematic experience for our customers,” said Laure de Boissard, Managing Director, Pathé Cinéma France. “Samsung Onyx allows us to achieve stunning visuals with exceptional brightness and contrast, ensuring that every film is presented exactly as intended.”
      Samsung Onyx is redefining how movies are experienced through its collaboration with the film industry as well. One such example was Samsung partnering with Pixar Animation Studios to master films like “Elemental,” “Inside Out 2,” and this summer’s “Elio” in HDR for Onyx, which led to the films being shown with exceptional brightness, contrast and color accuracy. Through close collaboration with filmmakers, Onyx continues to push the boundaries of display technology, ensuring that creative visions are brought to life with unmatched precision and clarity.
      “At Pixar, we believe cinema can be a grand, shared experience — a place where stories feel larger than life and memories are made with friends. That’s why we’re driven to bring something truly new to the big screen with our pioneering HDR-1 theatrical releases,” said Dominic Glynn, Senior Scientist, Pixar Animation Studios. “In rising to meet this ambition, the ONYX screen technology delivers astonishing brightness, clarity and color — an image so clear and uniform it elevates every moment of the story. Even the casual moviegoer will feel the difference. It’s about creating that unforgettable ‘Wow!’ — the kind of experience that reminds us why cinema is, and always should be, special.”
      CinemaCon attendees can experience the next-generation Onyx firsthand at Samsung’s booth at Caesars Palace, where the company will showcase its latest advancements in cinema display technology. Running March 31-April 3 in Las Vegas, CinemaCon is the largest annual gathering for the motion picture theater industry, bringing together theater owners, filmmakers, studio executives and industry professionals from all over the world.
      For more details, visit samsung.com.
      1 Digital Cinema Initiatives (DCI) is a consortium of major studios formed to establish specifications for an open architecture for digital cinema systems.
      2 Based on the screen’s internal data bandwidth. Actual frame rates may vary depending on the connected IMB.
      4 Peak brightness supported when using DCI-HDR supported IMB.
      5 Based on internal research and publicly available information. Onyx includes a standard three-year warranty, with options to extend coverage up to 10 years.
