Are your apps ready for the recently unveiled Galaxy Z Fold3? For your app to work seamlessly on foldable devices, it will need to correctly handle App Continuity and Flex Mode.
With Remote Test Lab, you can test your apps on a real Galaxy Z Fold3. To begin, create an account or login on Samsung Developers, and then visit this link to access the Galaxy Z Fold3.
Other recent devices, such as the Galaxy Tab S7+, Galaxy S21 Ultra, and Galaxy Note20 Ultra are also available on Remote Test Lab.
    • By mramnesia97
      My Samsung Smart TV's (Model Code: QE55Q80AATXXC) app window is completely broken. I'm trying to enable developer mode but as soon as I enter "Apps" the window is frozen. I cannot scroll or click on anything. I can activate to press the 123 digits, but nothing happens when I try to input 1,2,3,4,5
      I've tried resetting the TV completely, unplugged it, cleared cache and everything else I can think off.
      What could possibly cause the Apps drawer to not work and be completely frozen?
    • By Sau
      Hello,
      I have Samsung TV (qe55q80datxxh) with Tizen OS and unfortunately it doesn’t find necessary apps on its store. I.e. App called “TV Zone” (https://tvzone.app) - it supports Tizen OS, but on Samsung store it is not visible. Is there any way to install this app in Samsung via store or like a third party app using usb stick (is it even possible?)?
      Txanx!
    • By Mohammad1403
      Hello there,
      In Samsung TV Du8000
      Can I set a pin to prevent adding new apps?
      Or may I create a user profile that can't aad/remove apps then make it the default one?
    • By Geen
      What blatant f***** is your TV application?!!!!
