The Samsung Developers team works with many companies in the mobile and gaming ecosystems. We're excited to support our friends, Arm, as they bring timely and relevant content to developers looking to build games and high-performance experiences. This Best Practices series will help developers get the most out of the 3D hardware on Samsung mobile devices.
Developing games is a true cross-disciplinary experience for developers, requiring both technical and creative skills to bring their gaming project to life. But all too often, the performance and visual needs of a project can be at odds.
Leading technology provider of processor IP, Arm has developed artists’ best practices for mobile game development where game developers learn tips on creating performance-focused 3D assets, 2D assets, and scenes for mobile applications. Before you cut those stunning visuals, get maximum benefit from Arm's best practices by reviewing these four topics: geometry, texturing, materials and shaders, and lighting.
Geometry
To get a project performing well on as many devices as possible, the geometry consideration of a game should be taken seriously and optimized as much as possible. This section identifies what you need to know about using geometry properly on mobile devices.
On mobile, how you use vertices matters more then almost any other platform. Tips around how to avoid micro triangles and long thin triangles are great first steps in gaining performance.
The next big step is to use Level of Details (LOD). An LOD system uses a lower-poly version of the model as an object moves further away from the camera. This helps keep the vertex count down and gives control over how objects look far away to the artist. This otherwise would be left to the GPU, trying its best to render a high number of vertices in only a few pixels, costing the performance of the project.
To learn more, check Real-time 3D Art Best Practices: Geometry.
Texturing
Textures make up 2D UI and are also mapped to the surface of 3D objects. Learning about texturing best practices can bring big benefits to your game! Even a straightforward technique such as texture aliasing, where you build multiple smaller textures into one larger texture, can bring a major performance gain for a project.
You should understand what happens to a texture when the application runs. When the texture is exported, the common texture format is a PNG, JPG, or TGA file. However, when the application is running, each texture is converted to specific compression formats that are designed to be read faster on the GPU. Using the ASTC texture compression option not only helps your project’s performance, but also lets your textures look better.
To learn other texturing best practices, such as texture filtering and channel packing, check Real-time 3D Art Best Practices: Texturing.
Materials and shaders
Materials and shaders determine how 3D objects and visual effects appear on the screen. Become familiar with what they do and how to optimize them.
Pair materials with texture atlas’s, allowing multiple objects in the same scene to share textures and materials. The game engine batches this object when drawing them to screen, saving bandwidth and increasing performance.
When choosing shaders, use the simplest shader possible (like unlit) and avoid using unnecessary features. If you are authoring shaders, avoid complicated match operations (like sin, pow, cos, and noise). If you are in doubt about your shaders’ performance, Arm provides tools to perform profiling on your shaders with the Mali Offline Shader Compiler.
There is a lot more to learn, so check out Real-time 3D Art Best Practices: Materials and Shaders for more information.
Lighting
In most games, lighting can be one of the most critical parts of a visual style. Lighting can set the mood, lead game play, and identify threats and objectives. This can make or break the visuals of a game. But lighting can quickly be at odds with the performance needs of the project. To help avoid this hard choice, learn about the difference between static and dynamic light, optimization of light, how to fake lighting, and the benefits of the different type and settings of lights.
Often on mobile, it is worth faking as much as possible when it comes to shadows. Real time shadows are expensive! Dynamic objects often try using a 3D mesh, plane, or quad with a dark shadow texture for a shadow rather than resorting to dynamic lights.
For dynamic game objects, where you cannot fake lighting, use light probes. These have the same benefits of light maps and can be calculated offline. A light probe stores the light that passes through empty space in your scene. This data can then be used to light dynamic objects, which helps integrate them visually with lightmapped objects throughout your scene.
Lighting is a large topic with lots of possible optimizations. Read more at Real-Time 3D Art Best Practices in Unity: Lighting.
Arm and Samsung devices
Arm’s Cortex-A CPUs and Mali GPUs power the world’s smartphones, with Mali GPUs powering mobile graphics. This means you can find Arm GPUs in an extensive list of popular Samsung devices, including the Samsung Galaxy A51 and Galaxy S21. Arm provides practical tips and advice for teams developing real time 3D or 2D content for Arm-based devices.
Mobile game performance analysis has never been more important
Every year mobile gaming grows! It is now worth 77.2 billion US dollars in revenue in 2020. Growth in this sector is expected to continue in 2021 and beyond. With more mobile devices coming out each year, it is important for your content to be able to run on as many devices as possible, while providing players with the best possible experience.
The Artist Best Practices is just one part of the educational materials from Arm. Alongside these best practices, you can explore the Unity Learn Course, Arm & Unity Presents: 3D Art Optimization for Mobile Applications. This course includes a downloadable project that shows off the many benefits of using the best practices.
For more advanced users, check out Arm’s Mali GPU Best Practices Guide and learn about performance analysis with Arm Mobile Studio.
Follow Up
Thanks to Joe Rozek and the team at Arm for bringing these great ideas to the Samsung Developers community. We hope you put these best practices into effect on your upcoming mobile games.
The Samsung Developers site has many resources for developers looking to build for and integrate with Samsung devices and services. Stay in touch with the latest news by creating a free account or by subscribing to our monthly newsletter. Visit the Marketing Resources page for information on promoting and distributing your apps and games. Finally, our developer forum is an excellent way to stay up-to-date on all things related to the Galaxy ecosystem.
      The cinema industry is undergoing a profound transformation. As audiences increasingly seek premium and luxury experiences, theaters are evolving to deliver immersive, differentiated environments — and Samsung Electronics is at the forefront of this revolution.
      Raising the bar for cinema innovation, Samsung unveiled the latest model of Onyx (ICD) in March. The next generation of cinematic experiences will be defined by immersive visuals, improved comfort and a reliable viewing experience.
      In this article, Samsung Newsroom takes a closer look at the company’s vision for the future of cinema in terms of Visuals, Space and Consistency.
      ▲ Samsung Onyx was the center of attention at the company’s booth at CinemaCon 2025, the industry’s largest exhibition
      Visuals — An Out-of-This-World Screen Experience
      Immersion is at the heart of the cinematic experience — a setting designed to transport audiences into the world of the film. Only in an environment free from the everyday distractions such as constant calls, notifications and household chores can viewers fully engage with the story unfolding on the screen.
      A true cinematic experience faithfully delivers the filmmaker’s vision, presenting every detail, color and shadow exactly as intended. Onyx brings that vision to reality.
      ▲ Pixar’s Inside Out 2 shown on Samsung Onyx, demonstrating the display’s peak brightness and vibrant color accuracy
      Onyx, the world’s first cinema LED display certified1 by Digital Cinema Initiatives (DCI), delivers superior picture quality in 4K HDR resolution with vivid colors, deep blacks and infinite contrast. The clarity, precision and rich detail in each frame help give life to the narrative. Gone are the days of poor edge resolution and inconsistent brightness.
      ▲ Samsung Onyx enhances Pixar’s Lightyear (top) and Soul (bottom) with outstanding contrast, making dark scenes more vivid and immersive
      The Onyx screen can lend its brightness and clarity to applications other than movie screenings — live sports, concerts, gaming events and corporate presentations, for example. The ability to host alternative content empowers theaters to diversify their offerings and create new revenue streams without compromising the premium viewing experience.
      ▲ A live concert seen on Onyx, demonstrating the display’s color accuracy and sharp details
      Space — More Room for Comfort and Flexibility
      Comfort and spatial design are also key factors that set premium cinemas apart. Much like the distinction between economy and business class on an airplane, the seating experience can make or break a theater’s appeal. As theaters evolve into premium auditoriums, spacious, comfortable seating becomes essential.
      Onyx helps enable this transformation. Unlike traditional projectors which require separate projection rooms and large setups, Onyx’s cinema LED technology maximizes the available space in a theater. This allows cinemas to optimize their auditorium spaces and provides more flexibility to install specialized seating like larger recliners or dining tables.
      Furthermore, new Onyx (ICD) offers flexible scaling options, allowing screens to be customized to fit the dimension of each auditorium, ensuring the best use of space without sacrificing picture quality and comfort.
      ▲ Pixar’s Elio screened on Samsung Onyx featuring luxury seating for a premium cinema experience
      With Onyx, every seat in the theater offers a reliable high-quality visual experience — no edge distortion or resolution loss — ensuring that the entire audience is fully immersed in the story. The combination of optimized space, enhanced comfort and stunning visuals elevates the overall cinema experience.
      ▲ Samsung Onyx empowers theaters to deliver a premium cinema experience and luxury dining for customers.
      Consistency — Reliable Viewing Quality With Smarter Management Tools
      We go to the theater to be transported — to lose ourselves in the world of a story. But experiences in traditional projection-based theaters can deteriorate with picture quality that varies depending on the age and condition of the equipment.
      Samsung’s Cinema LED screen, on the other hand, features an ‘Auto Calibration Solution’ that automatically adjusts color consistency across each module, ensuring optimal picture quality — not just at installation, but every step of the way through ongoing maintenance.
      Onyx also offers the industry’s first and longest 10-year warranty for cinema LED,2 raising the bar for long-term reliability in cinema technology.
      ▲ Samsung Onyx, an out-of-this-world cinema LED display
      Since debuting the world’s first Cinema LED screen in 2017, Onyx has built strong partnerships with major global film studios, earning trust and recognition across the industry. As the leader in Cinema LED technology, Samsung is committed to pushing boundaries — so the magic of the movies is always seen exactly as it was meant to be.
      With Samsung Onyx, the future of premium cinema is brighter, clearer and more immersive than ever before.
      1 Digital Cinema Initiatives (DCI) is a consortium of major film studios established to define specifications for an open architecture in digital cinema systems.
      2 Based on internal research and publicly available information. Onyx includes a standard three-year warranty, with options to extend coverage up to 10 years.
      “Samsung’s QLED technology played a crucial role in bringing quantum dots to the level of recognition needed for the Nobel Prize in Chemistry.”
      Quantum dots have been at the forefront of display innovation over the past decade, delivering some of the most accurate color reproduction among existing materials. In 2015, Samsung Electronics paved the way for the commercialization of quantum dots with the launch of SUHD TVs — a breakthrough that moved beyond the use of cadmium (Cd), a heavy metal traditionally utilized in quantum dot synthesis, by introducing the world’s first no-cadmium quantum dot technology.
      The academic world took notice. The successful commercialization of cadmium-free quantum dot TVs not only set a new direction for research and development but also played a pivotal role in the awarding of the 2023 Nobel Prize in Chemistry for the discovery and synthesis of quantum dots.
      Following Part 1, Samsung Newsroom uncovers how Samsung has contributed to academia through groundbreaking advances in material innovation.
      ▲ (From left) Taeghwan Hyeon, Doh Chang Lee and Sanghyun Sohn
      Why Cadmium Was the Starting Point for Quantum Dot Research
      “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Quantum dots began attracting scientific interest in the 1980s when Aleksey Yekimov, former Chief Scientist at Nanocrystals Technology Inc., and Louis E. Brus, a professor emeritus in the Department of Chemistry at Columbia University, each published their researches on the quantum confinement effect and the size-dependent optical properties of quantum dots.
      Momentum accelerated in 1993 when Moungi Bawendi, a professor in the Department of Chemistry at the Massachusetts Institute of Technology (MIT), developed a reliable method for synthesizing quantum dots. In 2001, Taeghwan Hyeon, a distinguished professor in the Department of Chemical and Biological Engineering at Seoul National University (SNU), invented the “heat-up process” — a technique for producing uniform nanoparticles without the need for size-selective separation. In 2004, Hyeon published a scalable production method in the academic journal Nature Materials — a discovery widely regarded as a potential game changer in the industry.
      However, these efforts did not immediately lead to commercialization. At the time, quantum dots relied heavily on cadmium(Cd) as a core material — a substance known to be harmful to humans and designated as a restricted material under the European Union’s Restriction of Hazardous Substances (RoHS) Directive.
      “Currently, the only materials capable of reliably producing quantum dots are cadmium selenide (CdSe) and indium phosphide (InP),” explained Hyeon. “Cadmium selenide, the conventional quantum dot material, is a compound of group II and group VI elements, while indium phosphide is formed from group III and group V elements. Synthesizing quantum dots from group II and VI elements is relatively straightforward, but combining group III and V elements is chemically much more complex.”
      ▲ A comparison of cadmium-based quantum dots with ionic bonds and indium-based quantum dots with covalent bonds
      Cadmium, an element with two valence electrons, forms strong ionic bonds1 with elements like selenium (Se), sulfur (S) and tellurium (Te) — each of which has six valence electrons. These combinations result in stable semiconductors, known as II–VI semiconductors, materials that have long been favored in research for their ability to produce high-quality nanocrystals even at relatively low temperatures. As a result, the use of cadmium in quantum dot synthesis was considered an academic standard for many years.
      In contrast, indium (In) — an alternative to cadmium with three valence electrons — forms covalent bonds2 with elements such as phosphorus (P), which has five valence electrons. Covalent bonds are generally less stable than ionic bonds and have a directional nature, increasing the likelihood of defects during nanocrystal synthesis. These characteristics have made indium a challenging material to work with in both research and mass production.
      “It is difficult to achieve high crystallinity in quantum dots made from indium phosphide,” Lee noted. “A complex and demanding synthesis process is required to meet the quality standards necessary for commercialization.”
      No Compromise – From Breakthrough to Mass Production
      “There is simply no room for compromise when it comes to consumer safety.”
      Samsung, however, took a different approach.
      “We had been researching and developing quantum dot technology since 2001,” said Sanghyun Sohn, Head of Advanced Display Lab, Visual Display (VD) Business at Samsung Electronics. “But early on, we determined that cadmium — which is harmful to the human body — was not suitable for commercialization. While regulations in some countries technically allow up to 100 parts per million (ppm) of cadmium in electronic products, Samsung adopted a zero-cadmium policy from the start. No cadmium, no compromise — that was our strategy. There is simply no room for compromise when it comes to consumer safety.”
      Samsung’s long-standing commitment to its principle of “No Compromise on Safety” came to the forefront in 2014 when the company successfully developed the world’s first no-cadmium quantum dot material. To ensure both durability and image quality, Samsung introduced a triple-layer protective coating technology that shields indium phosphide nanoparticles from external factors such as oxygen and light. The following year, Samsung launched the world’s first commercial SUHD TV with no-cadmium quantum dots — a paradigm shift in the display industry and the culmination of research efforts that began in the early 2000s.
      “Indium phosphide-based quantum dots are inherently unstable and more difficult to synthesize compared to their cadmium-based counterparts, initially achieving only about 80% of the performance of cadmium-based quantum dots,” said Sohn. “However, through an intensive development process at the Samsung Advanced Institute of Technology (SAIT), we successfully raised performance to 100% and ensured reliability for more than 10 years.”
      ▲ The three components of quantum dots
      Quantum dots found in Samsung QLEDs are composed of three key components — a core, where light is emitted; a shell, which protects the core and stabilizes its structure; and a ligand, a polymer coating that enhances oxidation stability outside the shell. The essence of quantum dot technology lies in the seamless integration of these three elements, an advanced industrial process that spans from material acquisition and synthesis to mass production and the filing of numerous patents.
      “None of the three components — core, shell or ligand can be overlooked,” added Lee. “Samsung’s technology for indium phosphide synthesis is outstanding.”
      “Developing a technology in the lab is a challenge in itself, but commercialization requires an entirely different level of effort to ensure product stability and consistent color quality,” said Hyeon. “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Setting the Quantum Dot Standard
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs.”
      The optical properties of quantum dots are being applied to a wide range of fields, including solar cells, medicine and quantum computing. However, the quantum dot display remains the most actively researched and widely commercialized application to date — with Samsung emerging as a pioneer.
      Building on years of foundational research and the introduction of its SUHD TVs, Samsung launched its QLED TVs in 2017 and set a new standard for premium displays. In 2022, the company pushed innovation further with the debut of QD-OLED TVs — the world’s first display to combine quantum dots with an OLED structure.
      ▲ A comparison of LCD, QLED and QD-OLED structures
      QD-OLED is a next-generation display technology that integrates quantum dots into the self-emissive structure of OLED. This approach enables faster response times, deeper blacks and higher contrast ratios. Samsung’s QD-OLED was awarded Display of the Year in 2023 by the Society for Information Display (SID), the world’s largest organization dedicated to display technologies.
      “Samsung has not only led the market with its indium phosphide-based quantum dot TVs but also remains the only company to have successfully integrated and commercialized quantum dots in OLEDs,” said Sohn. “By leveraging our leadership in quantum dot technology, we will continue to lead the future of display innovation.”
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs,” said Doh Chang Lee, a professor in the Department of Chemical and Biomolecular Engineering at the Korea Advanced Institute of Science and Technology (KAIST). “Since its launch, discussions have increasingly focused on practical applications rather than the materials themselves, reflecting the potential for real-world implementation through display technologies.”
      “There have been many attempts to apply quantum dots in various fields including photocatalysis,” he added. “But these efforts remain in the early stages compared to their use in displays.”
      Hyeon also noted that the successful commercialization of Samsung’s quantum dot TVs helped pave the way for Bawendi, Brus and Yekimov to receive the 2023 Nobel Prize in Chemistry.
      “One of the most important criteria for the Nobel Prize is the extent to which a technology has contributed to humanity through commercialization,” he said. “Samsung’s QLED represents one of the most significant achievements in nanotechnology. Without its commercialization, it would have been difficult for quantum dots to earn Nobel recognition.”
      Samsung’s Vision for Tomorrow’s Displays
      Since the launch of its QLED TVs, Samsung has accelerated the growth of quantum dot technology in both industry and academia. When asked about the future of quantum dot displays, the experts shared their insights on what lies ahead.
      “As a next-generation technology, we are currently exploring self-emissive quantum dots,” said Sohn. “Until now, quantum dots have relied on external light source to express red and green. Going forward, we aim to develop quantum dots that emit light independently through electroluminescence — producing all three primary colors by injecting electrical energy. We are also working on the development of blue quantum dots.”
      “As electroluminescent materials make it possible to reduce the size of device components, we’ll be able to achieve the high resolution, efficiency and brightness required for virtual and augmented reality applications,” said Lee, predicting a major transformation in the future of displays.
      “A good display is one the viewer doesn’t even recognize as a display,” said Sohn. “The ultimate goal is to deliver an experience that feels indistinguishable from reality. As a leader in quantum dot display innovation, we will proudly continue to move forward.”
      With its continued leadership and bold technological vision, Samsung is shaping the future of displays and rewriting what’s possible with quantum dots.
      1 An ionic bond is a chemical bond formed when electrons are transferred between atoms, creating ions that are held together by electrical attraction.
      2 A covalent bond is a chemical bond in which two atoms share electrons.
      ▲ Samsung Onyx was the highlight of the company’s exhibition at CinemaCon 2025.
      Samsung Electronics reaffirmed its leadership as a pioneer in cinema LED technology at CinemaCon 2025, the ‘largest and most important gathering of movie theater owners from around the world,’ held in Las Vegas, Nevada from March 31 to April 3. At this event, Samsung unveiled the latest Samsung Onyx cinema LED screen with its unmatched picture quality, industry-leading reliability, and expanded scalability to meet the evolving needs of theaters worldwide.
      With nearly 6,000 industry professionals from more than 80 countries coming together to celebrate the moviegoing experience, CinemaCon is essential for companies that serve the cinema industry. Samsung invited industry professionals to its immersive booth to discover the latest in premium theater technology and watch films from leading studios.
      ▲ Attendees arriving at CinemaCon 2025 at Caesars Palace, Las Vegas; Inside Out 2 displayed on Samsung’s QMD supersized 105” signage
      Redefining Luxury Theater Experiences with Samsung Onyx
      At the booth, theater owners and industry leaders had a chance to experience films, including Elio (2025) on the new Samsung Onyx screen, showing attendees a cinematic experience that is unmatched with true black levels, infinite contrast ratio, and exceptional color accuracy.
      ▲ Pixar’s Elio screened on Samsung Onyx at CinemaCon 2025
      The new Samsung Onyx screen supports frames up to 4K 120Hz1 to deliver ultra-smooth motion and razor-sharp quality that brings out more details on screens. Further, Onyx can reach peak brightness levels of 300 nits (86.7fL), six times brighter than traditional cinema standards, which means the brightest details on the screen remain visible to the audience.2
      While traditional projectors often appear dim in larger theaters and struggle with washed-out colors in bright scenes, Samsung Onyx maintains exceptional brightness to reveal rich details in shadows, intense highlights and stunning color accuracy across the spectrum.
      “The color and vibrancy are very rich,” said Cynthia Lusk, Director of Creative Film Services and International Production at Pixar Studios. “On the Onyx display, there are details of the characters shown that I haven’t seen on a screen before.”
      ▲ A colorful scene from Pixar’s Inside Out 2 during a screening on Samsung Onyx at CinemaCon
      This year’s Onyx offers theater owners four standard sizes3 – 5 meters (16 feet), 10 meters (33 feet), 14 meters (46 feet), and 20 meters (66 feet) – with additional flexible scaling options to accommodate a variety of theater dimensions.
      Cannon Beach, a mixed use development blending lifestyle and adrenaline in Mesa, Arizona, will be the first location in the United States to introduce the latest generation of Samsung Onyx in its movie theater, LVL 11 Entertainment.
      ▲ Opening in Fall 2025, LVL 11 Entertainment at Cannon Beach will be the first cinema in the United States to introduce the latest generation of Samsung Onyx in an auditorium with a balcony, creating a unique viewing experience built around the Cinema LED screen.
      “We chose to partner with Samsung because its commitment to innovation and cutting-edge technology aligns perfectly with our vision for LVL 11 Entertainment. By premiering the Samsung Onyx Cinema LED Screen in Arizona, we will be offering an entirely new experience, not just a movie,” said Adam Saks, Chief Operating Officer, LVL 11 Entertainment. “Samsung’s ability to push the boundaries of entertainment technology ensures that LVL 11 at Cannon Beach remains at the forefront of the industry.”
      Digitizing In-Theater Movie Promotion with Color E-Paper
      ▲ Floor maps showcased on Samsung Color E-Paper displayed at the Samsung booth, demonstrating the screen’s paper-like display and slim depth.
      Outside the theater, Samsung introduced new digital signage to help theater owners transform the entire moviegoing experience.
      Samsung Color E-Paper is an ultra-low power, lightweight and slim display that can replace traditional analog and paper-based promotions while delivering the high visibility and functionality. A dedicated mobile app allows theater owners to seamlessly operate the display remotely, and schedule wake-up and sleep times. With Samsung VXT managing the content of Color E-Paper, updating is simplified as theaters change displays to promote the next upcoming blockbuster.
      Immersive Theater Lobbies with Cinematically Designed Signage
      ▲ Information about Elio(Pixar, 2025) displayed on Samsung’s QMD supersized 105” signage with a Samsung kiosk
      Samsung’s QMD series 105-inch supersized screen delivers a unique viewing experience, immersing moviegoers with a large screen before they step into the auditorium. Featuring a cinematic 21:9 ratio, the QMD is designed to captivate the audience, enhance brand visibility and enhance the overall theater environment.
      Transforming Menu Boards with Appetizing Visuals
      ▲ Samsung QMC signage displayed at CinemaCon, showcasing its vivid colors and dynamic content to captivate attendees before they enter the Onyx theater
      Samsung QMC signage will immediately draw movieogers upon arrival, showcasing one billion shades of color and allowing theaters to display their food and beverage offerings in a more engaging manner. The QMC’s slim profile enables theaters to optimize their space, seamlessly blending the display into any theater environment.
      ▲ CinemaCon 2025 official poster contest winners
      Samsung’s participation at CinemaCon underscores its pioneering excellence and continued legacy in cinema LED display. Industry experts, theater owners, and studios witnessed how Samsung is ushering in the future of cinematic innovation and leadership to build excitement for the future of films.
      1 Based on the screen’s internal data bandwidth. Actual frame rates may vary depending on the connected IMB. 4K resolution support applies to Onyx’s four standard sizes.
      2 Peak brightness supported when using DCI-HDR supported IMB.
      3 All measurements in meters and feet refer to screen width, while all measurements in inches denote diagonal; The 10-meter Onyx screen is now available for order, with other models arriving in a phased rollout.
      ▲ Samsung Neo QLED 4K TV (QN85F)
      Samsung Electronics today announced that its smart TVs and monitors will now support Netflix shows and movies in HDR10+.1 With HDR10+, viewers can enjoy richer contrast, deeper colors and stunning visual depth, making their favorite Netflix titles more immersive than ever.
      “HDR10+ enhances the way we watch content, delivering deeper contrast and more vibrant colors for a truly cinematic experience,” said Taeyong Son, Executive Vice President of Visual Display Business at Samsung Electronics. “We are excited to bring this technology to Netflix’s 300 million plus members and will continue collaborating with various partners to expand HDR10+ support across our product lineup and the broader streaming ecosystem.”
      HDR10+ is a next-generation high dynamic range (HDR) technology pioneered by Samsung, designed to optimize picture quality scene by scene. By dynamically adjusting brightness and contrast levels, HDR10+ ensures that each frame is displayed with exceptional clarity and detail, staying true to the creator’s intent.
      With this integration, viewers can experience enhanced realism and depth across a growing library of HDR10+ content, making every scene feel more lifelike. HDR10+ content on Netflix will be accessible on 2025 Samsung Neo QLED, OLED and Lifestyle TVs — as well as 2025 and 2024 monitor models — with support for additional models in the future.
      This launch marks a significant step in expanding HDR10+ content, bringing enhanced picture quality to more viewers. In addition to Netflix, Samsung is actively working with a growing network of industry partners to further extend HDR10+ support. For more information on Samsung TV, please visit www.samsung.com.
      1 Samsung co-established HDR10+ Technologies LLC in 2018 to provide a royalty-free, open dynamic metadata standard in the industry.
