As working from home becomes more commonplace around the world, people are increasingly looking to arrange their workspace so that they can work productively, comfortably and efficiently. But despite our best efforts, sometimes our personal devices don’t offer the capability to review multiple files at once or switch easily between multiple windows as we might require.
This is where Samsung’s high-resolution monitor, the S65UA, comes in. The 34-inch wide screen with 21:9 aspect ratio can help you enjoy a ‘work-from-home’ experience that mirrors the one you have in your office, as you can easily work across web browsers, document files and messenger programs at once – all on one screen.
The spacious desktop screen of the S65UA lets you multitask efficiently and smartly without any extra accessories or clutter on your desk, and its ergonomic stand design lets you customize your setup according to your home working environment. In order to take a closer look at the benefits of the S65UA for those working at home, Samsung Global Newsroom tried out some of its leading features.
Easy Installation and Upcycling-Friendly Packaging
After purchasing new electronic devices such as monitors, we are often left with a plethora of packaging boxes and materials to have to deal with once installation is complete. However, the S65UA comes with upcycling-friendly eco-packaging, meaning you can transform the monitor’s packaging into various practical tools, including objects for your pets and small furniture.
The S65UA’s eco-friendly packaging user manual is also simple to access and easy to use. Simply open up the packaging box, take out the components, and then flatten out the box. With your smartphone, scan the QR code that is printed on the side of the box, and you’ll see a detailed guide to installation. The cardboard packaging box comes with a special dot design that lays out the box’s dimensions in dots rather than centimeters. This means that anyone can create furniture without the need for extra tools to accurately measure the packaging’s lengths.
The next step is to install the monitor itself. The S65UA monitor comes with a stand base, stand neck, power cable, HDMI cable, and USD Type-C cable, so firstly, check you have all the components you need to continue.
The ensuing installation can be roughly divided into two steps. First, put the rectangle-shaped stand base onto the long stand neck and tightly fasten the connecting screw at the bottom of the stand base. When assembling the monitor, all you need to do is just tightly fasten the big screw in the middle. Secondly, simply push the assembled stand base and neck into the back part of the main body, and you’re done. Gently push it upward and you’ll hear a “click” noise, which means you’re all done with the assembly.1
▲ Looking at the dented area on the back of the S65UA monitor, there are 4 additional ports (HDMI, DP, Type-C, LAN).
The S65UA comes with a variety of port types to allow for multifaceted connectivity. Whatever connectivity needs you might have, you can easily connect your monitor to your other devices. In particular, the USB Type-C port can be used to connect portable devices such as smartphones and laptops. With a single cable alone, you can go beyond just connecting the device to the display monitor and enjoy up to 90W charging and fast 10Gbps data transmission for both convenience and versatility.
Customizable Height with an Ergonomic Stand
Productivity can directly be linked to the environment one works in. Even if a device possesses the best performance specs, if it doesn’t match the user’s posture or field of sight, it will become uncomfortable to use after a while. This is why the S65UA comes with a Height Adjustable Stand (HAS), which lets you quickly and easily adjust the height of the monitor by up to 120.00mm (±5.0mm). Simply hold the connecting part of the stand at the back of the monitor and move the monitor up and down to easily and smoothly adjust the height of your screen.
When using the monitor at its highest possible height, you’ll notice that you have extra desk space beneath it to utilize or decorate according to your preference, whether you’re looking for a space to store those extra files or to place some small plants and other flora.
The S65UA also comes with a swivel feature that lets you rotate the monitor to each side by up to 30.0˚(±2.0˚) to further enhance your work productivity. Regardless of which side of the monitor the user is at, the user can rotate their monitor in order to look at the entire screen. This feature also helps you utilize the space you have more effectively. When adjusting the monitor angle, it’s a good idea to gently hold the bezel rather than the display to gently adjust the monitor.
The S65UA monitor opens up more desk space once you’ve oriented it to your desired place, making work productivity and even cooperative work much more convenient. Regardless of how many people are surrounding the monitor, you can quickly and seamlessly peruse the monitor as needed to examine it. Not only does this harness the 178-degree wide viewing angle of the S65UA to its full potential, but it also lets you check the content on-screen instantaneously.
Sitting in front of a monitor for a long time can put unwanted pressure on your body – and a lot of this has to do with our posture in front of screens. If you become used to slouching with your neck leaning forward, the surrounding muscles can become stiff and painful. But thanks to the tilt functionality of the S65UA, you can find the perfect angle to keep you sitting straight and reduce the pressure on your muscles.
Unlike traditional monitors that may have been too tall or too short for optimal viewing experiences, the monitor adjustment capabilities of the S65UA make for a working environment that is more comfortable. What’s more, when taking a break and settling in to watch a movie on-screen for an extended period of time, you can then adjust your monitor some more for the most comfortable viewing experience.
A Wide Screen for All Activities
The S65UA offers a wide screen experience that doesn’t affect your field of sight thanks to its 1,000R display curvature for eye comfort and Ultra-Wide Quad High-Definition (QHD) (3,440 x 1,440) resolution. In addition, the monitor delivers more than 1 billion colors enhanced by HDR10 technology, resulting in true-to-life images and next-level immersion. Whether it’s the dew drops on plant leaves or the small wrinkles on flower petals, the display shows images in vivid, vibrant picture quality, with all colors from light to dark presented without any light blur or clarity obscuration. This creates the best possible viewing conditions for when you need to concentrate on on-screen details, such as when you are playing a game or watching media content.
Those who are accustomed to using dual monitors in the office will find the Easy Setting Box particularly useful. By pressing the control panel button, located on the back of the logo below the middle part of the monitor, you can choose the best aspect ratio from various options whenever you want. Also, Picture By Picture(PBP) shows two input sources on the same screen side by side along with the Picture In Picture (PIP) feature which enables you to open up a small pop-up window within your screen.
Unlike when you have to use multiple monitors to complete a task, there is no need for you to deal with height or color differences across screens, and you can enjoy the near gapless continuity of the monitor’s virtually borderless design for uninterrupted and seamless working experiences.
In order to protect users’ eyes from becoming dry after working for extended periods of time, all monitors from the Samsung 2021 high-resolution lineup come with features that help protect the eyes, leading these monitors to be Intelligent Eye Care certified by TÜV Rheinland, a certification institution of global standards and specifications based in Germany.
New to the 2021 monitor lineup, Adaptive Picture eye care technology automatically adjusts the brightness and color temperature of your screen to one of 42 levels when the environment you are in changes – for example, when your surroundings become darker after working in a bright environment, the monitor adjusts its settings in response to the room conditions. If you’d like to reduce blue light emissions which cause eye strain, you can turn on the special Eye Saver mode by pressing the control panel button. What’s more, Flicker Free technology, which reduces the flickering on the screen to protect your vision, also comes in helpful to maintain your eye health.
In times like this when the home has become blurred with the workplace, the ‘best monitor’ has evolved to become the one that is able to be flexible in response to the user’s environment and delivers the best performance wherever it may be. As well as encouraging you to strike the best balance between work and play while working from home, the S65UA helps increase your work efficiency with ease and comfort.
1 When assembling the monitor, please refer to the user manual that comes with the product.
      ▲ Samsung Neo QLED 4K TV (QN85F)
      Samsung Electronics today announced that its smart TVs and monitors will now support Netflix shows and movies in HDR10+.1 With HDR10+, viewers can enjoy richer contrast, deeper colors and stunning visual depth, making their favorite Netflix titles more immersive than ever.
      “HDR10+ enhances the way we watch content, delivering deeper contrast and more vibrant colors for a truly cinematic experience,” said Taeyong Son, Executive Vice President of Visual Display Business at Samsung Electronics. “We are excited to bring this technology to Netflix’s 300 million plus members and will continue collaborating with various partners to expand HDR10+ support across our product lineup and the broader streaming ecosystem.”
      HDR10+ is a next-generation high dynamic range (HDR) technology pioneered by Samsung, designed to optimize picture quality scene by scene. By dynamically adjusting brightness and contrast levels, HDR10+ ensures that each frame is displayed with exceptional clarity and detail, staying true to the creator’s intent.
      With this integration, viewers can experience enhanced realism and depth across a growing library of HDR10+ content, making every scene feel more lifelike. HDR10+ content on Netflix will be accessible on 2025 Samsung Neo QLED, OLED and Lifestyle TVs — as well as 2025 and 2024 monitor models — with support for additional models in the future.
      This launch marks a significant step in expanding HDR10+ content, bringing enhanced picture quality to more viewers. In addition to Netflix, Samsung is actively working with a growing network of industry partners to further extend HDR10+ support. For more information on Samsung TV, please visit www.samsung.com.
      1 Samsung co-established HDR10+ Technologies LLC in 2018 to provide a royalty-free, open dynamic metadata standard in the industry.
      ▲ Zhu Jinshi’s This Triptych is as Gorgeous as the Autumn in a Scented Room (2023) shown on Neo QLED 8K by Samsung.
      Samsung Electronics, the Official Art TV of Art Basel, today announced that it is bringing contemporary masterpieces from galleries exhibiting at Art Basel Hong Kong 2025 to a global audience. Starting today, subscribers of the Samsung Art Store, a premium digital art platform exclusively available on Samsung TVs, will have access to a curated collection of 23 select works from Art Basel’s galleries, some of which will be displayed at the highly anticipated fair, taking place from March 28-30,1 2025 at the Hong Kong Convention & Exhibition Centre.
      The Samsung Art Store is home to 3,000+ works from world-renowned museums, galleries and artists. Subscribers can explore expertly curated masterpieces in stunning 4K resolution to bring the program of Art Basel galleries into their homes. The Art Basel Hong Kong collection includes renowned artworks such as Zhu Jinshi’s “This Triptych is as Gorgeous as the Autumn in a Scented Room,” Ticko Liu’s “Enduring as the Universe,” Jimok Choi’s “Shadow of the Sun,” Bae Yoon Hwan’s “Green Bear,” and more.
      “Samsung Art Store is making fine art more accessible than ever, bringing the premier artworks presented by leading international galleries at Art Basel Hong Kong directly into people’s homes,” said Bongjun Ko, Vice President of Samsung Electronics’ Visual Display Business. “We are proud to expand this experience to more Samsung TV owners worldwide, allowing them to enjoy world-class artwork in stunning 4K quality with just a few clicks.”
      Bringing the Art Basel Experience to Samsung TVs
      ▲ Ticko Liu’s Enduring as the Universe (2024) shown on Neo QLED 8K by Samsung.
      Art Basel stages the world’s premier art shows for modern and contemporary art, sited in Hong Kong, Basel, Paris and Miami Beach. Through the Samsung Art Store, a curated selection of these masterpieces is now available beyond the exhibition halls, allowing art lovers worldwide to experience select artworks presented by leading international galleries at Art Basel – all from the comfort of their homes.
      To further highlight the intersection of art and technology, Samsung will present an interactive lounge, titled ArtCube,2 at Art Basel Hong Kong on March 28-30. The showcase will demonstrate how The Frame, MICRO LED and Neo QLED 8K redefine digital art experiences by displaying artwork, including those from the Art Basel collection in breathtaking detail. Under the theme “Borderless, Dive into the Art,” ArtCube visitors will engage with Samsung Art Store’s exclusive collections, bridging the gap between physical and digital art.
      In addition to its ArtCube Lounge experience, Samsung presents a series of panel discussions highlighting influential voices from the contemporary art scene. Daria Greene, Head of Content and Curation at Samsung leads each engaging one-on-one dialogue. The conversations feature Hayley Romer, Chief Growth Officer of Art Basel, and Marc Dennis, an American artist known for his hyper-realistic paintings.
      Expanding Samsung’s Digital Art Leadership
      While previously exclusive to The Frame and MICRO LED, the Samsung Art Store will soon be available on 2025 Samsung AI-powered Neo QLED and QLED TVs,3 as part of Samsung’s mission to bring world-class art to an even bigger audience. In addition to the Art Basel Hong Kong collection, Samsung will continue its partnership with one of the world’s most prestigious art fairs by introducing exclusive artworks from Art Basel’s Basel and Paris collections later this year.
      “We are proud to partner with Samsung Art Store on the 2025 Art Basel Hong Kong collection – extending Art Basel Hong Kong’s best-in-class cultural experience beyond the halls of the show, and creating new, year-round opportunities for ever broader audiences to engage with Art Basel’s distinguished international program of galleries and their artists,” said Noah Horowitz, CEO of Art Basel.
      The Art Basel Hong Kong collection features works from 23 globally acclaimed artists, including Jimok Choi, Bae Yoon Hwan, Stephen Wong Chun Hei, Ticko Liu, Alasie Inoue, Tromarama, Damian Elwes, Zhu Jinshi, Nakai Katsumi, Cao Yu, Hamra Abbas, Nabil Nahas, Owen Fu, Sophie von Hellermann, Chow Chun Fai, Gillian Ayres and Gongkan.
      About Art Basel
      Founded in 1970 by gallerists from Basel, Art Basel today stages the world’s premier art shows for Modern and contemporary art, sited in Basel, Miami Beach, Hong Kong, and Paris. Defined by its host city and region, each show is unique, which is reflected in its participating galleries, artworks presented, and the content of parallel programming produced in collaboration with local institutions for each edition. Art Basel’s engagement has expanded beyond art fairs through new digital platforms including the Art Basel App and initiatives such as the Art Basel and UBS Global Art Market Report and the Art Basel Awards. Art Basel’s Global Lead Partner is UBS. For further information, please visit artbasel.com.
      1 Event is open to the public from March 28-30, after VIP opening from March 26-27.
      2 Samsung Lounge ‘ArtCube’ will be located in L3, the main exhibition floor inside the Hong Kong Convention and Exhibition Center.
      3 For models Q7F and above.
      Samsung Electronics America has secured #1 rankings in TVs for overall customer satisfaction and #1 in home appliance service experience for the second year in row in the 2024 American Customer Satisfaction Index (ACSI®) survey. Samsung TVs also achieved #1 in product quality, service quality and service experience.1
      Samsung research shows that 90% of TV buyers and 94% of home appliance shoppers are more likely to choose a brand known for strong customer service2 — a trust that Samsung has built through consistent commitment to customer care. Building on this trust, Samsung is leading the way in designing AI-enabled products that enhance consumers’ lives, with the cutting-edge Samsung Care team ready to assist when the unexpected happens.
      “We’re proud to be consistently recognized by our customers in the ACSI survey, a testament to the improvements we have made to the end-to-end customer experience,” said Mark Williams, Vice President of Customer Care at Samsung Electronics America. “We know that when your TV or appliance isn’t working, you want it fixed quickly, the first time. That is why we’ve invested in AI and digital care innovations, best-in-class training, efficient parts distribution and expanding our Samsung Beyond Boundaries,3 program to provide more customers with quality care in the US.”
      Samsung TVs: Excellence in Picture and Sound Quality, Value and More
      Samsung received recognition from its customers across several categories for its cutting-edge TVs, powered by AI. This includes #1 rankings in overall quality, picture quality, and sound quality — a clear testament to our continued leadership and innovation.
      With AI at its core, the 2024 lineup delivers several value-add features that only Samsung can provide, demonstrated by a #1 ranking in value. This includes AI Upscaling,4 which can transform even lower-resolution content — like old movie classics — into stunning 4K and 8K, and Samsung Gaming Hub,5 letting you experience the best of gaming all in one place, no console required. With Tizen OS, you can stream all of your favorite video services and access Samsung TV Plus, which provides 2,700+ free channels, including 400+ premium channels — all for free.
      In a world that is more connected than ever before, Samsung TVs users can effortlessly enjoy entertainment knowing their devices are ranked #1 for connectivity. With seamless access to SmartThings, you can use your TVs as an IoT hub to easily connect and manage devices. Powered by Knox, only Samsung TVs deliver added peace of mind that your personal data is secured across your connected devices while you watch.6
      Samsung TVs also earned #1 rankings for ease of use, exterior design and durability. From sustainability-forward packaging and improved energy efficiency to accessibility features — the TV lineup is intentionally designed to elevate your home entertainment experience.
      Samsung Home Appliances: Leading Customer Satisfaction
      Samsung achieved best-in-class rankings for refrigerators7 and washing machines, and leads in appliances with top scores for service experience, ease of arranging service, technician courtesy, helpfulness and timely repairs. These top rankings reflect the confidence consumers place in Samsung’s AI-enabled products to enhance and simplify their lives.
      Our latest AI-powered Bespoke appliances were designed to deliver enhanced performance, helping you do more with less effort. The Bespoke Refrigerator with AI Family Hub+ with AI Vision Inside recognizes 33 different food items as they’re added or removed from the fridge, using an internal camera and ‘Vision AI’ technology.8 The Bespoke AI Laundry Combo All-in-One takes the guesswork out of cycle selection by intelligently adjusting washing and drying time and energy.9 The AI Home touchscreen LCD Display simplifies cycle and setting selection while managing other connected Samsung devices. And with SmartThings, the #1 mobile app for appliances according to ACSI,10 AI-equipped devices seamlessly connect, offering smarter home management and easier control.11
      Empowering Customers with Seamless, Next-Generation Care
      Samsung Care continuously invests in ways to give customers choices and easy options for high-quality, convenient care on their terms. Paving the way in next-generation care, Samsung has continued to invest in AI-powered tools to help Care experts resolve issues even faster. Interactive Voice Response (IVR) is one such tool, using AI12 to identify the customer’s intent, product, and issue, ensuring they are routed to the right agent with valuable insights before the call even begins. IVR can also text customers the two nearest Walk-In Service or Authorized Repair Centers based on their zip code and send a link to book an appointment, making the process even smoother.
      With connected solutions for home appliances, Samsung makes proactive and preventative care simple and accessible. For example, consumers can use the Home Care service in the SmartThings app, which uses AI to automatically detect and troubleshoot issues. If an error code appears, customers receive an alert with step-by-step instructions for a quick home fix. If further assistance is needed, they can chat with a care professional, schedule a repair with a Samsung-certified technician, or even order replacement parts, like water filters, directly through the app.
      Samsung provides 99.9%13 of the U.S. with convenient Care coverage for TVs and home appliances. Even in rural areas, people can access next-level care via Samsung Beyond Boundaries. Customers within a 4-hour radius of a Samsung Care Center can receive at-home repairs.
      Looking for more news or need additional support from the Samsung Care Team? Visit the Samsung Care YouTube Channel, check out the Samsung Members App and Samsung Communities or text us any time by messaging 1-800-SAMSUNG to start a conversation with a Samsung Care Pro.
      About the American Customer Satisfaction Index (ACSI®) Survey
      The American Customer Satisfaction Index Survey (ACSI) is the nation’s only cross-industry measure of customer satisfaction. Since 1994, the survey has been recognized as a leader in analyzing consumer sentiment about the products and services used most often. The ACSI Index surveys customers on their own consumer electronics experiences and identifies industry leaders for excellence, based on customer feedback regarding service repair, product durability, and warranty coverage.
      Between July 2023 and June 2024, the ACSI Household Appliance and Electronics Study surveyed over 5,100 U.S. consumers who recently purchased appliances from leading manufacturers to evaluate the quality of their experiences in a variety of categories. Between July 2023 and June 2024, the ACSI TV Study surveyed over 6,000 U.S. consumers who recently purchased TVs from leading manufacturers to evaluate the quality of their experiences in a variety of categories.
      Source: 2024 ACSI® Surveys of customers rating their appliance manufacturer and TV manufacturer. ACSI and its logo are registered trademarks of the American Customer Satisfaction Index. For more about ACSI, visit www.theacsi.org.
      1 Samsung tied with 1 other brands for service experience.
      2 Samsung Electronics American Consumer Market Insights, Customer Care Foundational Learnings — March 2024
      3 Coverage includes 99.9% of delivery zip codes (excluding P.O. box, APO/FPO/DPO) by our largest retailer; in-warranty service only.
      4 Utilizes AI-based formulas.
      5 Powered by Tizen, the Samsung Gaming Hub is an all-in-one game streaming discovery platform bridging hardware and software for a better player experience. Instantly play thousands of games from Xbox, NVIDIA GeForce NOW, Amazon Luna, Utomik, Antstream Arcade and Blacknut Cloud Gaming. The Samsung Gaming Hub is the new home for gaming and entertainment with Twitch, Spotify and YouTube Gaming integration that gives players easy access to enhance their experience. No storage limits, no downloads, no console or PC required – all players need is a Bluetooth-enabled gaming controller and internet connection to start playing.
      6 Personal data includes input Pin codes and passwords, and IoT device information through the SmartThings app. The latest software update is required.
      7 Samsung tied with 1 other refrigerator brand.
      8 Available on RF23DB9900. As of March 2024, AI Vision Inside can recognize 33 food items like fresh fruits and veggies. Recognizable food items will be regularly added and updated. If the food is covered by hand and not recognizable, it may be listed as an unknown item, but the user can always revise the item title through the Family Hub or SmartThings. Wi-Fi connection and Samsung account required.
      9 Messages with cycle suggestions are displayed on the control panel or a smartphone with the SmartThings app; available on Android and iOS devices. A Wi-Fi connection and a Samsung account are required. Can be applied on Towels, AI Opti Wash & AI Optimal Dry, Heavy Duty, Super Speed, Small Load cycle only when the selected washing temperature is ‘hot’. Based on internal testing with IEC 8lb load except for Small Load cycle (IEC 4lb load). Results may vary depending on the actual usage conditions.
      10 Samsung tied with one other mobile app for home appliances.
      11 Available on Android and iOS devices. A Wi-Fi connection and a Samsung account are required.
      12 After IVR does the initial triage with the customer, AI analyzes the intent and passes info along to the Care agent to better address the need. IVR continuously learns and improves its accuracy over time, enabling our agents to support customers more quickly.
      13 Coverage includes 99.9% of delivery zip codes (excluding P.O. box, APO/FPO/DPO) by our largest retailer; in-warranty service only.
      Samsung Electronics’ The Premiere is back and more powerful than ever, after revolutionizing the premium projector market with its 2020 debut. Apart from its celebrated home cinema capabilities, The Premiere lineup has been enhanced with an array of new lifestyle features to broaden functionality beyond mere video viewing.
      Samsung Newsroom met with developers Jaeyoung Park, Seonbin Jang and Jonguk Shin from the Visual Display Business at Samsung Electronics to discuss The Premiere’s new features and next steps for the projector.
      ▲ (From left) Jaeyoung Park, Seonbin Jang and Jonguk Shin
      Ultra-Short Throw: Embracing a New Era of Home Cinema
      Within a year of its launch in 2020, The Premiere ascended to the top of the premium projector market in North America — achieving this feat by delivering an unparalleled home cinema experience to users.
      The true value of The Premiere’s home cinema features became evident during the COVID-19 pandemic. As more people stayed at home, the online streaming industry expanded and brought projectors into the spotlight. The ultra-short throw projector segment, a category that includes The Premiere, represented just 7.2%1 of the premium home cinema projector market in 2019. However, following the pandemic, this share grew to 22.5% by 2023.
      ▲ The Premiere 9
      The Premiere’s biggest advantage lies in its convenience. Utilizing ultra-short throw technology with an aspherical mirror, the projector eliminates the need for ceiling mounts or a separate shelf to achieve an optimal projection distance. Users can simply place The Premiere directly in front of the desired wall, much like a TV, and screen adjustments can be made effortlessly via a remote control or mobile device. The Premiere 9 and The Premiere 7 are ideal for creating a personal movie theater, offering immersive screen sizes of up to 130 and 120 inches, respectively.
      Color Wheel: Rotates rapidly in sync with the video signal to ensure images display the correct colors. Typically features 3 to 8 color sections.
      Digital Micromirror Device (DMD): Precisely adjusts millions of tiny mirrors mounted on a microchip according to the video signal. This part is crucial in creating high image quality and resolution on projectors.
      Triple Laser Technology: Fires lasers of the three primary colors of light — red, green and blue — to produce bright, sharp images. Contributes to brighter projections by reducing light loss in steps such as the color wheel.
      Aspherical Mirror: Allows for ultra-short throw projection. Following numerous simulations, Samsung engineers came up with the optimal curvature and applied it to the new The Premiere projector.
      ▲ A simplified conceptualization of two major Digital Light Processing (DLP) beam projector types
      “The remarkable thing about ultra-short throw projectors is their ability to create a large screen with minimal space between the device and wall,” said Shin, who led development for The Premiere. “The Premiere 9, for instance, creates a 100-inch screen with just 9.4 inches of space between the wall and device.”
      ▲ The Premiere 9 can project screens up to 130 inches. (Note: Screen sizes in column A measured diagonally, not vertically)
      “Home cinema projectors are all about delivering the best possible screen experience within a given space.”
      – Jonguk Shin, Visual Display Business, Samsung Electronics
      Upgrading With a Focus on Lifestyle
      Following a successful debut, the team wanted more. They were resolute in transforming The Premiere into a comprehensive lifestyle product with value extending beyond home cinema.
      “Our goal was to offer a wider range of use for The Premiere users,” explained Jang, who led product planning for The Premiere.
      ▲ Customize your space and set the right mood by projecting photos, color effects, background scenes and themes on your wall with The Premiere.
      Custom Ambient, one of the newly added features, allows users to freely edit photos and videos through the SmartThings app on their smartphone and project them onto the wall. Users can even place widgets like a real-time clock onto the wall for everyday décor or use an animated effect like waves to make a splash during a party.
      “Custom Ambient draws inspiration from The Freestyle’s Ambient Mode which is frequently used to upload social media posts,” he continued. “With The Premiere, users can create their own personalized space, even when they’re not watching videos.”
      ▲ Jaeyoung Park discusses The Premiere’s new lifestyle features of The Premiere.
      Now with Samsung Gaming Hub installed, the projector’s entertainment capabilities have been significantly enhanced. Users can enjoy games from the cloud on the big screen without connecting a PC or gaming console. Of course, there are also plenty of HDMI slots (three) for those who want to connect PCs or gaming consoles, too.
      “I often play racing games with my kids at home, and The Premiere’s 100-inch screen is perfect for the four of us to play on via split-screen without feeling cramped,” said Park.
      ▲ There are notable aesthetic differences between the first (left in each picture) and new (right) versions of The Premiere. The 2024 version features a more compact front with a warmer shade of Kvadrat fabric to better match home décor.
      When turned off, The Premiere can also function as a smart speaker.
      “The Premiere 9 features a built-in 40W 2.2.2 channel up-firing speaker that delivers powerful sound,” he added. “The Premiere 9 features front-firing units like a soundbar along with ample space for audio to resonate for deeper, richer acoustics compared to other form factors. Bixby can help users to enjoy immersive audio without turning on the screen with voice commands to stream music or launch podcast apps.”
      Brighter With Advanced Laser Technology
      Unlike TVs in which users view light directly from the panel, projectors reflect light off the projection surface. As a result, the right components and software technology are necessary to achieving high image quality. Advanced laser technology also contributes to The Premiere’s large crystal-clear screen. The Premiere 9 utilizes triple laser technology, leveraging laser light sources from the three primary colors red, green and blue. In contrast, The Premiere 7 employs single laser technology with a blue light source, supporting a wider color gamut and higher color accuracy compared to lamp-based or LED projectors.
      The Premiere 9 and The Premiere 7 deliver up to 154% and 100% of the DCI-P32 color gamut, respectively, and both models support HDR10+ to ensure crisp, vibrant images even in bright environments.
      ▲ The Premiere 9 features triple laser technology for brighter, sharper images.
      Another key strength of The Premiere lineup is the abundant brightness offered.
      “The Premiere 9 delivers a peak brightness of up to 3,450 ISO lumens3 with triple laser technology, while The Premiere 7 offers up to 2,500 ISO lumens with single laser technology,” said Shin. “The higher maximum brightness provides clearer picture quality and a more comfortable viewing experience compared to previous models. The laser light source also boasts a long lifespan and consumes less power than traditional lamp-based projectors. In other words, maintenance costs may actually be lower.”
      Smarter, AI-Powered Home Cinema
      Despite its numerous usability features, the essence of The Premiere remains centered on watching videos.
      “In an internal survey of The Premiere users, 90% of respondents indicated that they purchased the device to watch movies,” said Jang.
      “Samsung’s robust hardware and AI technology, long recognized as No. 1 in TVs, have enhanced the picture and sound quality of The Premiere.”
      – Jaeyoung Park, Visual Display Business, Samsung Electronics
      To deliver a premium home cinema experience, the developers focused on elevating picture and sound quality. Automation through AI technology was key. With 4K AI Upscaling, The Premiere delivers vibrant 4K resolution and significant improvements in picture quality. The Vision Booster leverages a light sensor to automatically detect and adjust ambient brightness in real time and calibrate color and contrast using an algorithm for optimal picture quality.
      “The Premiere is smarter than ever before,” said Park. “Samsung’s robust hardware and AI technology, long recognized as No. 1 in TVs, have enhanced the picture and sound quality of The Premiere.”
      ▲ Jonguk Shin explains the advantages of ultra-short throw technology.
      While Samsung has retained the acclaimed built-in speakers from The Premiere’s predecessor, the 2024 lineup has introduced a variety of new AI features for audio as well. In addition to Dolby Atmos technology, an essential for immersive movie-watching, several AI-driven sound technologies have been incorporated including:
      Active Voice Amplifier (AVA) Pro, a feature that distinguishes voices from ambient noise and adjusts the voice volume accordingly. Object Tracking Sound (OTS), a feature that synchronizes sound with movements on screen. Adaptive Sound, a feature that automatically optimizes audio based on the surrounding environment.
      Additionally, Q-Symphony allows users to connect wireless speakers for a more holistic listening experience.
      ▲ The Premiere projectors feature a minimalist, warm white design with rounded edges and a premium fabric finish from Kvadrat, a Danish textile design company that seamlessly blends in with any home decor. In the back, there is a Digital Audio Out (Optical) port and three HDMI ports, a LAN port as well as ex-Link and IR ports for better remote control
      Transcending the Limits of Space for Immersion
      What started as a movie projector for theaters, the modern projector has thrived due to its unique ability to transcend space — overcoming the physical constraints of screen size and location. Now, the advent of ultra-short throw technology has significantly mitigated the issues of space and passer-by shadows traditionally associated with beam projectors.
      ▲ Seonbin Jang describes the appeal of projectors.
      As The Premiere continues to lead the way in the premium home projector market, what is next for this innovative device?
      “Our goal is to seamlessly integrate projector screens to more spaces, such as walls and ceilings in homes,” said Park.
      “The unique beauty of projectors is their ability to project beyond the physical confines of frame,” Jang reiterated. “In the future, we hope to evolve this into a spatial display that transcends the limitations of projection space — ultimately achieving a truly immersive screen experience, everywhere and anywhere.”
      “Home cinema projectors are all about delivering the best possible screen experience within a given space,” concluded Shin. “We are committed to overcoming physical constraints to maximize the consumer experience.”
      1 Mainstream & High-end Home Cinema category, excluding China, based on revenue. <Projector Reports> by PMA Research, March 2023
      2 The Digital Cinema Initiatives (DCI) standard color gamut
      3 Brightness level based on the International Organization for Standardization (ISO)
      Samsung Electronics today announced a partnership with Technogym to launch a new fitness app1 on Samsung Daily+ platform,2 expanding the health and wellness services available on Samsung’s 2024 TVs. The app offers personalized fitness routines and accommodates equipment-based and bodyweight exercises for a comprehensive home workout experience.
      “In 2024, Samsung TV users can now see the TV as not only a central entertainment hub but also a means to enrich the lifestyle— especially for fitness,” said Demian Hyun, Vice President and Head of the Experience Planning Group of the Visual Display Business at Samsung Electronics. “We’re excited to bring Technogym to Samsung TVs because the experience fits right in with our drive to provide more immersive and personalized experiences for users.”
      “Within our Technogym Ecosystem open platform strategy, the integration with Samsung TVs represents another step toward reaching more consumers within our wellness vision to help people live better lives through regular physical exercise,” said Nerio Alessandri, Technogym President and CEO.
      Trainer-Led Sessions and Customized Programs
      The Technogym app offers over 130 trainer-led sessions to help users reach their goals, perform better and stay motivated. Everything from high intensity cardio and bodyweight routines, to mindful yoga sessions, Pilates and meditations are led by Technogym’s certified trainers and are specially designed to be done in front of a screen.
      Upon signing into the Technogym app on Samsung Daily+, each user is greeted with training programs tailored to their personal goals, whether it is building strength, improving endurance or enhancing overall health. The app not only tracks and logs progress but also offers personalized recommendations, ensuring a workout regimen that adapts to users’ evolving fitness journeys.
      But the Technogym app isn’t just about individual workouts. It also curates a selection of popular workout sessions, including “Most Performed Routines” and “Most Loved Session Episodes.” These sessions are not just about getting fit; they are about joining a community, sharing trends and motivating each other through a shared fitness experience.
      Comprehensive Workout Options — Anytime, Anywhere
      The Technogym app on Samsung TVs elevates at-home workouts by offering ultimate convenience and access. The basic app is free, with the option for a premium subscription that provides access to exclusive, more in-depth workout content. Users can effortlessly track their workout history on any device through their Technogym account, ensuring a continuous and integrated fitness journey.
      Additionally, the app combines Samsung’s immersive screen technology with specialized workout programs using Technogym’s cutting-edge equipment for all-encompassing workout sessions.
      Users can browse a broad and diverse library with video training sessions, which include strength, yoga, cardio, Pilates, meditation and body weight. They can choose different levels, from beginner to the advanced. New workouts are published regularly so the experience remains fresh and engaging. Moreover, Samsung TV users can download the Technogym mobile app to access their personalized profile with the same credentials anytime and anywhere.
      About Technogym
      Technogym is a global leading brand in the wellness and fitness industry, is known for its premium equipment and fitness content that elevate the workout experience in both gyms and homes alike. As the official supplier for the last nine Olympic Games, including the upcoming Paris 2024 Olympics, Technogym’s cutting-edge equipment and extensive library of on-demand videos reach over 85,000 fitness centers and 400,000 homes around the world.
      1 Technogym app is available through Samsung Daily+ on all 2024 Samsung TV models: Neo QLED 8K, Neo QLED, OLED, UHD (above DU7000) and The Frame worldwide. TV model users can download the Technogym app through the app store. The content is provided primarily in English and supported with subtitles.
      2 Samsung Daily+, a hub for lifestyle experiences, provides a wide range of services and features — from personal training and telehealth to video calls and remote PC solutions — in one single interface.
