Apps will not install on Samsung Class 7 Series LED 4K UHD Smart Tizen TV - UN43TU7000FXZA
By mramnesia97
My Samsung Smart TV's (Model Code: QE55Q80AATXXC) app window is completely broken. I'm trying to enable developer mode but as soon as I enter "Apps" the window is frozen. I cannot scroll or click on anything. I can activate to press the 123 digits, but nothing happens when I try to input 1,2,3,4,5
I've tried resetting the TV completely, unplugged it, cleared cache and everything else I can think off.
What could possibly cause the Apps drawer to not work and be completely frozen?
By Sau
Hello,
I have Samsung TV (qe55q80datxxh) with Tizen OS and unfortunately it doesn’t find necessary apps on its store. I.e. App called “TV Zone” (https://tvzone.app) - it supports Tizen OS, but on Samsung store it is not visible. Is there any way to install this app in Samsung via store or like a third party app using usb stick (is it even possible?)?
Txanx!
By Mohammad1403
Hello there,
In Samsung TV Du8000
Can I set a pin to prevent adding new apps?
Or may I create a user profile that can't aad/remove apps then make it the default one?
Similar Tagged Content
Just bought 43" Class 7 Series LED 4K UHD Smart Tizen TV - UN43TU7000FXZA
By Autoguy,
- un43tu7000fxza
- 43
- (and 3 more)
- 0 replies
- 1,562 views
- 0 replies
- 3,718 views
Posted by Alex,
1 reaction
Go to this post
