This clip is part of a 2 hour Tizen online workshop that you can find here: https://youtu.be/5xp8jFpXOm8
In this video, we will create a small project and see how we can navigate through different pages using the Tizen Advanced UI.
You can also connect with me, Diego, a Sr. Developer Evangelist, on Twitter: https://twitter.com/hielo777
Have questions? Post them in our forums: https://forum.developer.samsung.com/
Check out other videos, blog posts, and tips to improve your Tizen app development.
Check the Tizen Tidbits playlist on our YouTube channel, and learn more about the wide selection of Samsung technologies on our developer portal.
      “Samsung’s QLED technology played a crucial role in bringing quantum dots to the level of recognition needed for the Nobel Prize in Chemistry.”
      Quantum dots have been at the forefront of display innovation over the past decade, delivering some of the most accurate color reproduction among existing materials. In 2015, Samsung Electronics paved the way for the commercialization of quantum dots with the launch of SUHD TVs — a breakthrough that moved beyond the use of cadmium (Cd), a heavy metal traditionally utilized in quantum dot synthesis, by introducing the world’s first no-cadmium quantum dot technology.
      The academic world took notice. The successful commercialization of cadmium-free quantum dot TVs not only set a new direction for research and development but also played a pivotal role in the awarding of the 2023 Nobel Prize in Chemistry for the discovery and synthesis of quantum dots.
      Following Part 1, Samsung Newsroom uncovers how Samsung has contributed to academia through groundbreaking advances in material innovation.
      ▲ (From left) Taeghwan Hyeon, Doh Chang Lee and Sanghyun Sohn
      Why Cadmium Was the Starting Point for Quantum Dot Research
      “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Quantum dots began attracting scientific interest in the 1980s when Aleksey Yekimov, former Chief Scientist at Nanocrystals Technology Inc., and Louis E. Brus, a professor emeritus in the Department of Chemistry at Columbia University, each published their researches on the quantum confinement effect and the size-dependent optical properties of quantum dots.
      Momentum accelerated in 1993 when Moungi Bawendi, a professor in the Department of Chemistry at the Massachusetts Institute of Technology (MIT), developed a reliable method for synthesizing quantum dots. In 2001, Taeghwan Hyeon, a distinguished professor in the Department of Chemical and Biological Engineering at Seoul National University (SNU), invented the “heat-up process” — a technique for producing uniform nanoparticles without the need for size-selective separation. In 2004, Hyeon published a scalable production method in the academic journal Nature Materials — a discovery widely regarded as a potential game changer in the industry.
      However, these efforts did not immediately lead to commercialization. At the time, quantum dots relied heavily on cadmium(Cd) as a core material — a substance known to be harmful to humans and designated as a restricted material under the European Union’s Restriction of Hazardous Substances (RoHS) Directive.
      “Currently, the only materials capable of reliably producing quantum dots are cadmium selenide (CdSe) and indium phosphide (InP),” explained Hyeon. “Cadmium selenide, the conventional quantum dot material, is a compound of group II and group VI elements, while indium phosphide is formed from group III and group V elements. Synthesizing quantum dots from group II and VI elements is relatively straightforward, but combining group III and V elements is chemically much more complex.”
      ▲ A comparison of cadmium-based quantum dots with ionic bonds and indium-based quantum dots with covalent bonds
      Cadmium, an element with two valence electrons, forms strong ionic bonds1 with elements like selenium (Se), sulfur (S) and tellurium (Te) — each of which has six valence electrons. These combinations result in stable semiconductors, known as II–VI semiconductors, materials that have long been favored in research for their ability to produce high-quality nanocrystals even at relatively low temperatures. As a result, the use of cadmium in quantum dot synthesis was considered an academic standard for many years.
      In contrast, indium (In) — an alternative to cadmium with three valence electrons — forms covalent bonds2 with elements such as phosphorus (P), which has five valence electrons. Covalent bonds are generally less stable than ionic bonds and have a directional nature, increasing the likelihood of defects during nanocrystal synthesis. These characteristics have made indium a challenging material to work with in both research and mass production.
      “It is difficult to achieve high crystallinity in quantum dots made from indium phosphide,” Lee noted. “A complex and demanding synthesis process is required to meet the quality standards necessary for commercialization.”
      No Compromise – From Breakthrough to Mass Production
      “There is simply no room for compromise when it comes to consumer safety.”
      Samsung, however, took a different approach.
      “We had been researching and developing quantum dot technology since 2001,” said Sanghyun Sohn, Head of Advanced Display Lab, Visual Display (VD) Business at Samsung Electronics. “But early on, we determined that cadmium — which is harmful to the human body — was not suitable for commercialization. While regulations in some countries technically allow up to 100 parts per million (ppm) of cadmium in electronic products, Samsung adopted a zero-cadmium policy from the start. No cadmium, no compromise — that was our strategy. There is simply no room for compromise when it comes to consumer safety.”
      Samsung’s long-standing commitment to its principle of “No Compromise on Safety” came to the forefront in 2014 when the company successfully developed the world’s first no-cadmium quantum dot material. To ensure both durability and image quality, Samsung introduced a triple-layer protective coating technology that shields indium phosphide nanoparticles from external factors such as oxygen and light. The following year, Samsung launched the world’s first commercial SUHD TV with no-cadmium quantum dots — a paradigm shift in the display industry and the culmination of research efforts that began in the early 2000s.
      “Indium phosphide-based quantum dots are inherently unstable and more difficult to synthesize compared to their cadmium-based counterparts, initially achieving only about 80% of the performance of cadmium-based quantum dots,” said Sohn. “However, through an intensive development process at the Samsung Advanced Institute of Technology (SAIT), we successfully raised performance to 100% and ensured reliability for more than 10 years.”
      ▲ The three components of quantum dots
      Quantum dots found in Samsung QLEDs are composed of three key components — a core, where light is emitted; a shell, which protects the core and stabilizes its structure; and a ligand, a polymer coating that enhances oxidation stability outside the shell. The essence of quantum dot technology lies in the seamless integration of these three elements, an advanced industrial process that spans from material acquisition and synthesis to mass production and the filing of numerous patents.
      “None of the three components — core, shell or ligand can be overlooked,” added Lee. “Samsung’s technology for indium phosphide synthesis is outstanding.”
      “Developing a technology in the lab is a challenge in itself, but commercialization requires an entirely different level of effort to ensure product stability and consistent color quality,” said Hyeon. “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Setting the Quantum Dot Standard
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs.”
      The optical properties of quantum dots are being applied to a wide range of fields, including solar cells, medicine and quantum computing. However, the quantum dot display remains the most actively researched and widely commercialized application to date — with Samsung emerging as a pioneer.
      Building on years of foundational research and the introduction of its SUHD TVs, Samsung launched its QLED TVs in 2017 and set a new standard for premium displays. In 2022, the company pushed innovation further with the debut of QD-OLED TVs — the world’s first display to combine quantum dots with an OLED structure.
      ▲ A comparison of LCD, QLED and QD-OLED structures
      QD-OLED is a next-generation display technology that integrates quantum dots into the self-emissive structure of OLED. This approach enables faster response times, deeper blacks and higher contrast ratios. Samsung’s QD-OLED was awarded Display of the Year in 2023 by the Society for Information Display (SID), the world’s largest organization dedicated to display technologies.
      “Samsung has not only led the market with its indium phosphide-based quantum dot TVs but also remains the only company to have successfully integrated and commercialized quantum dots in OLEDs,” said Sohn. “By leveraging our leadership in quantum dot technology, we will continue to lead the future of display innovation.”
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs,” said Doh Chang Lee, a professor in the Department of Chemical and Biomolecular Engineering at the Korea Advanced Institute of Science and Technology (KAIST). “Since its launch, discussions have increasingly focused on practical applications rather than the materials themselves, reflecting the potential for real-world implementation through display technologies.”
      “There have been many attempts to apply quantum dots in various fields including photocatalysis,” he added. “But these efforts remain in the early stages compared to their use in displays.”
      Hyeon also noted that the successful commercialization of Samsung’s quantum dot TVs helped pave the way for Bawendi, Brus and Yekimov to receive the 2023 Nobel Prize in Chemistry.
      “One of the most important criteria for the Nobel Prize is the extent to which a technology has contributed to humanity through commercialization,” he said. “Samsung’s QLED represents one of the most significant achievements in nanotechnology. Without its commercialization, it would have been difficult for quantum dots to earn Nobel recognition.”
      Samsung’s Vision for Tomorrow’s Displays
      Since the launch of its QLED TVs, Samsung has accelerated the growth of quantum dot technology in both industry and academia. When asked about the future of quantum dot displays, the experts shared their insights on what lies ahead.
      “As a next-generation technology, we are currently exploring self-emissive quantum dots,” said Sohn. “Until now, quantum dots have relied on external light source to express red and green. Going forward, we aim to develop quantum dots that emit light independently through electroluminescence — producing all three primary colors by injecting electrical energy. We are also working on the development of blue quantum dots.”
      “As electroluminescent materials make it possible to reduce the size of device components, we’ll be able to achieve the high resolution, efficiency and brightness required for virtual and augmented reality applications,” said Lee, predicting a major transformation in the future of displays.
      “A good display is one the viewer doesn’t even recognize as a display,” said Sohn. “The ultimate goal is to deliver an experience that feels indistinguishable from reality. As a leader in quantum dot display innovation, we will proudly continue to move forward.”
      With its continued leadership and bold technological vision, Samsung is shaping the future of displays and rewriting what’s possible with quantum dots.
      1 An ionic bond is a chemical bond formed when electrons are transferred between atoms, creating ions that are held together by electrical attraction.
      2 A covalent bond is a chemical bond in which two atoms share electrons.
      In Part 1 of this intro to Apache Cordova series, we were able to see how front-end developers could use standard web technologies to create cross-platform mobile applications, and the prerequisites to install Cordova in your dev environment.
      In this second part we are focused on creating your first application with Cordova, and how to publish your app in the Samsung Galaxy Store.
      Creating the App
      After installing Cordova, you should go to the file directory where you maintain your source code. There, you can create a Cordova project. This would be a simple Hello World project, but would give you an idea of the file structure of a Cordova project, and the different parts that you can modify to obtain the functionality you are looking for.
      In your terminal or command interface type:
      cd pathToYourProjects After that:
      cordova create CordovaProject com.example.hello CordovaApp
      CordovaProject is the directory name where the app is created. com.example.hello is the default reverse domain value (package name). You should use your own domain name if possible. CordovaApp is the title of your app. This creates the required directory structure for your Cordova app. By default, the Cordova create script generates a skeletal web-based application whose home page is the project's www/index.html file.
      Adding Platform
      Since Cordova works for multiple platforms, we have to add Android to the build settings. You need to open your project directory in the command prompt. In our example, it is the Cordova Project. You should only choose platforms that you need. To be able to use the specified platform, you need to have installed the specific platform SDK.
      All subsequent commands need to be run within the project's directory, or any subdirectories:
      cd CordovaProject
      Add the Android platform, since this is the target of app, and ensure they get saved to config.xml and package.json:
      cordova platform add android You can also remove a platform from your project by using:
      cordova platform rm android To make certain you have added all the platforms you are targeting you can type:
      cordova platform ls
      This should list all the added platforms for your current project.
      Checking the Install pre-requisites for building
      To build and run apps, you need to install SDKs for each platform you wish to target. Alternatively, if you are using browser for development you can use browser platform which does not require any platform SDKs.
      To check if you satisfy requirements for building the platform that you just added:
      cordova requirements
      This command should show you a result similar to this one:
      Requirements check results for android: Java JDK: installed . Android SDK: installed Android target: installed android-19,android-21,android-22,android-23,Google Inc.:Google APIs:19,Google Inc.:Google APIs (x86 System Image):19,Google Inc.:Google APIs:23 Gradle: installed Building the App
      This step builds the app for a specified platform so we can run it on mobile device or emulator.
      cordova build
      If you have added more than one platform to your project, you can limit the scope of each build to specific platforms. For our example we should add 'android':
      cordova build android Build for android platform in release mode and use the specified build configuration:
      cordova build android --release --buildConfig=..\myBuildConfig.json Testing the App
      Using Cordova’s emulator Now we can run our app. If you are using the default emulator you should use:
      cordova emulate android
      If you want to use the external emulator or real device you should use
      cordova run android Publishing your APK
      To check in detail how to take your binary files and publish them in the Samsung Galaxy Store, check this in-depth video:
      We love to chat with mobile game developers and help you as you develop, publish, and market your own games. Galaxy Store is a great place to publish your game and get discovered. If you are a mobile app developer and want to request a quick chat with us, just fill out this form.
