Alex Posted January 7, 2020 Report Posted January 7, 2020 An 8K TV in and of itself isn't really new. But they're getting ridiculously cool. The new QLED line from Samsung in 2020 is headed up by the Q950. It's Tizen-based, of course, which is the semi-open-source operating system the company has been using for years. (That's in contrast to things like webOS from LG, or Android TV, or Roku TV.) There's also plenty of AI baked in — because what doesn't have AI baked in at this point. And that'll do things like automatically adjust brightness and contrast based on the ambient light in the room. It'll also do its own thing to compress the video so that you're not sucking as much bandwidth as you might otherwise. (And Samsung says it's working directly with Amazon on this to scale up standard-definition content in Prime Video to 4K.) But what you'll absolutely notice is the near lack of a bezel. Samsung says there's a nearly 99 percent screen-to-body ratio, which essentially makes the bezel disappear. And the TV itself is 15mm thick and has a completely flat back, so it'll fit flush against a wall. And somehow Samsung has managed to cram killer audio into the Q950 as well. It's got speakers on each side of the display, and woofers in the back for virtual 5.1 audio. Will that be better than external speakers? Perhaps not. But it's still an incredible feat in a device that's less than 2 centimeters thick. And 2020's 8K TVs are making use of MicroLED panels across the board, from the 75-inch size all the way up to a monstrous 150 inches. That's allowing for the thinness and minuscule bezels. And it just looks good. Source: https://www.cordcutters.com/samsungs-newest-tvs-are-spectacular-and-almost-absolutely-are-not-you-yetv Quote
