I am developing an alarm management application on a wearable device. It is a Web application (HTML and Javascript). When the alarm is triggered, in addition to sending the alarm status to the control panel, it should record the sound all around the device. This recording should arrive, in real time, in the operations center, publishing the audio stream on the reference Wowza server.
Thanks in advance!
      Samsung In-App Purchase (IAP) offers developers a robust solution for handling digital transactions within mobile applications available on Galaxy Store. Whether it is selling digital goods, handling subscriptions, or managing refunds, Samsung IAP is designed to offer a smooth, secure experience. The Samsung IAP Orders API expands the scope of these benefits. You can fetch all the payments and refunds history according to specified dates. This content guides you through the essential components for implementing both the Samsung IAP and Samsung IAP Orders APIs.
      Figure 1: Sample Application UI In this tutorial, we provide a sample application called Book Spot, which offers users the option to subscribe to their favorite books and consumable items, such as text fonts, for purchase. After purchase, users can consume the item. Finally, developers can view all their payment and refund history on specific dates by calling the Samsung IAP Orders API from the back-end server.
      Prerequisites
      Before implementing in-app purchases in your app, do the following to enable a smooth and effective execution of the process while developing your own application:
      Integrate the Samsung IAP SDK into your application. For more information about the IAP SDK integration, you can follow the Integration of Samsung IAP Services in Android Apps article. Upload the application for Beta testing on Samsung Galaxy Store. A step-by-step guide with screenshots has been provided in the documentation. For more details, see the section “Production Closed Beta Test” on the Test Guide. Finally, create items on the Seller Portal so that users can purchase or subscribe to them while using the application. For more details about the available items that the Seller Portal supports, see the Programming Guide. For the sample application, we have already completed these steps. Some example items were already created in Seller Portal, such as books and fonts so that you can consume and subscribe to them while using this sample application.
      Implementation of Item Purchase
      Now that the application and items are ready, you can implement the purchase functionality in your application like in the sample below:
      When clicking "Buy," the startPayment() method is called, specifying parameters for item ID and the OnPaymentListener interface, which handles the results of the payment transaction. The onPayment() callback returns whether the purchase has succeeded or failed. The purchaseVo object is instantiated and in case it is not null, it holds the purchase results. If the purchase is successful, then it validates the purchase showing its ID. If the purchase is not successful, a purchaseError message is shown. For more information, check the Purchase an in-app item section. iapHelper.startPayment(itemId, String.valueOf(1), new OnPaymentListener() { @Override public void onPayment(@NonNull ErrorVo errorVo, @Nullable PurchaseVo purchaseVo) { if (purchaseVo != null) { // Purchase Successful Log.d("purchaseId" , purchaseVo.getPurchaseId().toString()); Toast.makeText(getApplicationContext() ,"Purchase Successfully", Toast.LENGTH_SHORT).show(); } else { Log.d("purchaseError" , errorVo.toString()); Toast.makeText(getApplicationContext() ,"Purchase Failed", Toast.LENGTH_SHORT).show(); } } }); Implementation of Item Consumption
      After successfully purchasing an item, the user can then consume it. In the sample code below, when "Consumed" is selected, the consumePurchaseItems() triggers the consume functionality. This is necessary as items must be marked as consumed so they can be purchased again:
      The consumePurchaseItems() method is called specifying the parameters for purchaseId and the OnConsumePurchasedItemsListener() interface, which handles the item data and results. This code also checks if consuming the purchased items succeeded or failed: If the errorVo parameter is not null and there is no error with the purchase, which can be verified with the IAP_ERROR_NONE response code, then the “Purchase Acknowledged” message is displayed. However, if there is an error, the errorVo parameter returns an error description with the getErrorString() getter, along with the “Acknowledgment Failed” message. iapHelper.consumePurchasedItems(purchaseId, new OnConsumePurchasedItemsListener() { @Override public void onConsumePurchasedItems(@NonNull ErrorVo errorVo, @NonNull ArrayList<ConsumeVo>arrayList) { if (errorVo != null && errorVo.getErrorCode() == iapHelper.IAP_ERROR_NONE) { Toast.makeText(getApplicationContext() ,"Purchase Acknowledged", Toast.LENGTH_SHORT).show(); } else { Toast.makeText(getApplicationContext(), "Acknowledgment Failed: " + errorVo.getErrorString(), Toast.LENGTH_SHORT).show(); } } }); Implementation of Item Subscription
      Besides purchasing and consuming items, you can also subscribe to them in your applications. Similar to the validation done for the consumable item purchase, you validate the subscription with a purchase ID if the purchase is successful. Use the same code snippet specified for “Item Purchase.” For more information, check the Implementation of Item Purchase section.
      Implementation of the Samsung IAP Orders API
      The Samsung IAP Orders API is used to view all payments and refunds on a specific date. It does this by fetching the payments and refunds history within the date you specified. Let’s implement the Samsung IAP Orders API and create a server to listen to its notifications. Through server-to-server communication, the API returns all orders data for the application.
      Configuring the Server
      You can develop a Spring Boot server for this purpose. Here are the guidelines on how to set up this server:
      Set up a Spring Boot Project. For more information, follow the steps on Developing Your First Spring Boot Application. Set up your server endpoint: Create a controller for the Samsung IAP Orders API in an integrated development environment (IDE) after importing the Spring Boot project you created. This helps managing all in-app order-related activities and processing them within your application.
      The controller receives POST requests sent from Samsung’s IAP orders service ensuring the communication with your application.
      Get Payment and Refund History
      To view all payments and refunds:
      You must make a POST request to the Samsung IAP Orders API endpoint with the required headers specified below. If you specify a date, all the payment history for this date is returned. Otherwise, it only returns all the data from the day before the current date. API Endpoint: https://devapi.samsungapps.com/iap/seller/orders
      Method: POST
      Headers:
      Add the following fields to the request header. For more information, see the Create an Access Token page, which helps you understand how to create the access token in detail. The token is used for authorization. You can also get the Service Account ID by clicking the Assistance > API Service tabs on Seller Portal. For more details, read the section Create a service account and visit Seller Portal.
      Header Name
      Description
      Required/Optional
      Values
      Content-Type
      Format of the request body
      Required
      application/json
      Authorization
      Authorization security header
      Required
      Bearer: access_token
      Service Account ID
      This ID can be created in Seller Portal and is used to generate the JSON Web Token (JWT)
      Required
      service-account-id
      Parameters:
      The following parameters can be used to build your POST request.
      Name
      Type
      Required/Optional
      Description
      sellerSeq
      String
      Required
      Your seller deeplink, which is found in your profile in Seller Portal and consists of a 12-digit number.
      packageName
      String
      Optional
      Used to view payment and refund data. You can provide the application package name. When a package name is not specified, the data for all applications is shown.
      requestDate
      String
      Optional
      Specify a date from which to view the payment and refund data. If the date is not specified, the data from a day before your current date is returned.
      continuationToken
      String
      Optional
      Use this if you want to check if there is a continuation for the data on the next page. If there is no more data, the response is null.
      To implement REST API support, add the following OkHttp library dependencies to your application's build.gradle file:
      implementation 'com.squareup.okhttp3:okhttp: version' implementation 'com.google.code.gson:gson: version' A detailed description of the request items can be found in the Request section of the Samsung IAP Orders API documentation. For more information on the server communication, see Samsung IAP Server API. Here is a brief summary of the code below:
      A POST request is mapped to the /orders URL, which logs the request. The previously described parameters containing the data you specified are formatted in a JSON body using the String.format() method. The outgoing request is logged in a JSON body format. A RequestBody is instantiated containing the JSON data, formatted for an HTTP request to be sent to the server with the specified token and Service Account ID. This code also handles multiple results your request can return: The onFailure() method is called when the network request fails for some reason, providing any error details using the IOException exception. If the request succeeds, the onResponse() method returns the response body or any response exception found. @RestController @RequestMapping(value = "/iap", method = RequestMethod.POST) public class OrdersController { private final OkHttpClient client = new OkHttpClient(); @GetMapping("/orders") public void sendToServer() { System.out.println("POST request received"); // Log the request // Define parameters values, use according to your requirement // String packageName = "com.example.app_name "; // String requestDate = "20240615"; // String continuationToken = "XXXXXXXXXXX…….XXXXXX"; String sellerSeq = "0000000XXXXX"; // Create the JSON body, use packageName, requestDate, continuationToken according to your requirement String jsonBody = String.format( "{\"sellerSeq\":\"%s\"}", sellerSeq ); // Create the request body RequestBody body = RequestBody.create(jsonBody, MediaType.parse("application/json; charset=utf-8")); // Access token String token = "0DjT9yzrYUKDoGbVUlXXXXXX"; // Build the request Request request = new Request.Builder() .url("https://devapi.samsungapps.com/iap/seller/orders") .post(body) .addHeader("Authorization","Bearer " + token) .addHeader("service-account-id", "85412253-21b2-4d84-8ff5-XXXXXXXXXXXX") .addHeader("content-type", "application/json") .build(); client.newCall(request).enqueue(new Callback() { @Override public void onFailure(@NotNull Call call, @NotNull IOException e) { System.err.println("Request failed: " + e.getMessage()); } @Override public void onResponse(@NotNull Call call, @NotNull Response response) throws IOException { if (response.isSuccessful()) { String responseBody = response.body().string(); System.out.println("Response: " + responseBody); } else { System.err.println("Unexpected response code: " + response.code()); System.err.println("Response body: " + response.body().string()); } response.close(); // Close the response body } }); } } Congratulations! You have just built the Spring Boot server to handle API POST requests using the OkHttpClient to manage HTTP requests and responses for your sample application.
      Example Response
      As previously mentioned, a JSON-formatted response is returned to your request. For detailed descriptions of each response body element, see the “Response” section of the Samsung IAP Orders API documentation. The following output format is a sample in which only some of the response-body data is presented.
      In this case, the continuationToken parameter key returns null because there is no continuation for the data on the next page. The orderItemList parameter key lists all the orders with specific details, such as orderId, countryId, packageName, among others. { "continuationToken": null, "orderItemList": [ { "orderId": "S20230210KR019XXXXX", "purchaseId": "a778b928b32ed0871958e8bcfb757e54f0bc894fa8df7dd8dbb553cxxxxxxxx", "contentId": "000005059XXX", "countryId": "USA", "packageName": "com.abc.xyz" }, { "orderId": "S20230210KR019XXXXX", "purchaseId": "90a5df78f7815623eb34f567eb0413fb0209bb04dad1367d7877edxxxxxxxx", "contentId": "000005059XXX", "countryId": "USA", "packageName": "com.abc.xyz" }, ] } Usually, the responses contain all the relevant information about user purchases, such as the in-app item title, price, and payment status. Therefore, you can use the information and create views for an easier order management.
      NoteIf the IAP operating mode is configured to test mode, the API response is empty. This is because the API is configured to operate and return a response only in production mode. Conclusion
      You have learned how to implement item purchase, consumption, and registration, as well as how to integrate the Samsung IAP Orders API and configure a server to fetch all the payment and refund history within specific dates.
      Integrating the Samsung IAP Orders API functionality into your server is an essential step in managing your application payments history to ensure a seamless experience to users. Now, you can implement the Samsung IAP Orders API into your application to track all payments, refunds and make your business more manageable.
      Related Resources
      For additional information on this topic, see the resources below:
      Download the Android Sample Application Source Code Add Samsung In-App Purchase service to your app Samsung IAP Orders API Integration of Samsung IAP Services in Android Apps View the full blog at its source
      Samsung Electronics today announced the official launch of its Visual eXperience Transformation (VXT) Platform, a cloud-native Content Management Solution (CMS) combining content and remote signage management on one secure platform. Designed with ease-of-use in mind, the all-in-one solution allows businesses to easily create and manage their digital displays.
      “Cloud migration is an unstoppable trend,” said Alex Lee, Executive Vice President of Visual Display Business at Samsung Electronics. “VXT is an innovative step toward this migration in that it makes high-tech signage more readily accessible, no matter where our customers are. But not only is high-tech signage accessible, the content and remote management solutions VXT provides are user-friendly.”
      Efficient Cloud-Native Solution for All Business Needs
      Samsung VXT is the next evolution of CMS software from MagicINFO, delivering an enhanced cloud-native solution tailored for seamless content creation and management of all B2B displays — including LCD, LED signage and The Wall. VXT streamlines the deployment and updating of software directly via a cloud portal, which eliminates the cumbersome process of manual updates. Registration of devices is designed for efficiency, as well, with a simple 6-digit pairing code that allows for quick and secure setup.
      By streamlining digital signage operations and management, VXT offers a versatile solution that meets the needs of any sector, whether it be retail, hospitality, food and beverage or corporate. The solution has already received recognition from prominent partners such as Hy-Vee’s retail media network, RedMedia, which uses VXT CMS to manage a network of over 10,000 Samsung smart signage screens — including the QBR-Series, which has been installed across all of Hy-Vee’s grocery stores and retail locations.
      Intuitive Content and Screen Management
      Unlike other CMS solutions, VXT is a turnkey solution developed by Samsung that allows users to seamlessly create content and manage screens in one application. It consists of three CMS modules: VXT CMS, VXT Canvas1 and VXT Players, and each module makes content creation and screen management easier than ever:
      VXT CMS: Content management is simplified through an intuitive interface that simultaneously handles content, playlists and schedules. The remote management feature allows real-time management of multiple devices. Additionally, robust security features — such as private certificates and allowing customizable security solutions for every business need. VXT Canvas: What You See is What You Get (WYSIWYG)-based creative tools that enable anyone to create content effortlessly and more intuitively with support for various templates, widgets and partner content. Users can create original content with custom and company fonts, as well as templates and images pre-loaded on the system for added convenience. VXT Players: VXT supports Tizen and Android-based players,2 while also managing multiple web elements simultaneously on one screen. Additionally, a web-based virtual screen allows users to easily view and manage their signage deployments.
      VXT also combines content, solutions and expertise of third-party system integrators, software developers and content partners to provide users with access to an even broader range of incredible content, specific to vertical use cases, without the need for additional customization or development.3 Some of the notable Pre-Integrated Repeatable Solutions (PIRS) include:
      VXT Art: Users can access a diverse library of artwork and photos with just a few clicks, and content from various art museums and galleries can be used across businesses ranging from office spaces to restaurants and beyond. Link My POS: This solution enabled by Wisar Digital allows businesses to use VXT Canvas to pull product data from Point Of Sale (POS) systems, eliminating the need to manually enter data or export data. Link My POS improves overall efficiency and reduces pricing errors, which in turn saves time and money. Ngine Real Estate: This solution developed through a partnership with Ngine Networks lets businesses display properties that are for sale or rent by using VXT to forego re-entering data when connecting directly to their platforms. Ngine Automotive: Cars, bikes and boats can be listed as for sale or rent by connecting directly to business displays, without needing to enter information. Messages can be resumed on social network platforms, as well. This solution has also been achieved by partnering with Ngine Networks.
      Seamlessly Control and Manage from Anywhere
      By offering compatibility with both desktop and mobile devices4, Samsung VXT revolutionizes content management because it caters to both the advanced needs of desktop users and the convenience required by mobile users. This flexibility allows users to manage their content anytime, anywhere.
      Furthermore, VXT is designed to substantially reduce downtime in digital signage operations. Through advanced modular architecture, VXT isolates and minimizes the impact of any potential failures, allowing users to swiftly address disruptions. VXT also comes with an early warning feature, which detects potential issues — such as extreme temperature changes or network instability — and alerts customers before failure occurs. This offers greater peace of mind by allowing users to take preemptive actions or speed up the recovery time.
      VXT’s energy management tool offers an at-a-glance view of energy consumption levels, as well. Customers can optimize their energy use based on monthly insights and adjust settings like brightness levels and automatic on/off times accordingly.
      Availability
      Samsung will hold a global launch event of VXT on January 31 at Integrated Systems Europe (ISE) 2024 in Barcelona. Designed as an omni-channel service, VXT will be accessible through various subscription plans, including both monthly and annual options. Customers can also make offline purchases through existing B2B sales channels worldwide, while online purchases will initially be made available in the U.S. before a subsequent global rollout in 2024. Prospective users can take advantage of a 60-day free trial before subscribing.
      For more information on Samsung’s VXT platform, please visit https://vxt.samsung.com.
      1 VXT CMS and VXT Canvas supported on Chrome browser only.
      2 VXT is compatible with Android devices running Android 10 or higher, and with Tizen devices on Tizen 6.5 or higher.
      3 For PIRS partner content, additional subscription payment is required.
      4 VXT CMS and VXT Canvas supported on Chrome browser only.
  • Similar Tagged Content
