sqlite3.dll load on z2 fails on z4
Earlier this year, SmartThings announced a new program called Certification by Similarity (CbS) within our Works with Samsung SmartThings (WWST) partner program. This program is designed for Smart Home OEM’s to be able to certify portfolios of products, rather than certifying each product one by one.
Additionally, we released a new developer feature called Product Cloning, which allows partners to input the details of one product and copy for all the similar products.
Many of our device manufacturing partners have a portfolio of devices that have the same smart technology on the inside but come in many different shapes, colors, and other variations. We are making it easier and more cost efficient than ever to certify the entire portfolio.
After releasing this new certification option, we have heard excellent reviews from our partners. Read on to discover how to take advantage of this new offering.
Product Cloning
SmartThings Product Cloning allows you to enter information for one product and clone it to generate multiple entries for all similar products. The similar products include all the critical information — all you need to do is update the unique identifiers, like the Matter Product ID and Model Number.
Easily copy product details and enter whole product lines
Save time and get certified faster
Get Started
How to clone a product:
Visit the SmartThings Certification Console. Navigate to the Products page (second icon from the top on the left). Enter your product details for one product and save it. Navigate back to the Products page. Under the Actions menu on the product, you have an option to create multiple products at once with Product Cloning.
You can add up to 10 clones with the option to enter the unique identifiers. Once created, the clones appear in your Products list; you can open them up and modify any of the details before submitting for WWST Certification.
WWST Certification by Similarity
Certification by Similarity (CbS) allows you to reduce your WWST certification time and cost by identifying related products with similar core functionality but with different model numbers and minor differences like colors, shapes, or regional variations.
Example Certification by Similarity use case with a portfolio of RGBW, RGB, and white balance light bulbs:
Start by submitting a primary product for certification that is a superset of all the portfolio features — such as one of the RGBW light bulbs. Once the primary product testing is complete, the similar devices — such as the RGB and white balance light bulbs — can get fast-tracked through certification, for free. Additional devices can be either submitted at the same time as the primary product or at a later date. All you need to do is submit the product information and link it with the primary product. We then verify that the features are the same as your primary product and grant you certification.
Devices that Can Be Considered for CbS
The following criteria must be met for the devices to be considered for CbS:
Note: Cloud Connected Devices may have different Device Profiles and still be considered for Certification by Similarity. This is possible only if the Capabilities for similar products are a subset of the primary product. If a similar device has additional Capabilities, partial testing is required.
Learn more about CbS in the Developer Documentation and Certification Console.
Get Started
How to submit similar products for WWST:
Visit the SmartThings Certification Console. Navigate to the Certifications page. Submit your primary product for certification. Navigate back to the Certifications page and select the target similar product to certify. You now have the option to link this submission with the primary product. Select the associated primary product and submit your product for certification.
Certification by Similarity FAQs
How is the primary product determined?
→ The primary product has all the Capabilities of other devices in the group. In this example, Product 4 or Product 5 could be the primary.
How can we guarantee CbS will be approved before submitting for WWST certification?
→ We recommend following the guidelines in the Developer Documentation. The WWST team makes the final decision after reviewing your submission.
Should I submit the primary product and wait for it to be fully certified before submitting secondary devices to be considered for CbS, or can all of the products be submitted together?
→ When submitting products, you do not need to wait. You can submit the primary product and similar products at the same time.
I have multiple brands, including some that have the same hardware and firmware. Can CbS be extended to these multiple brands?
→ In order to be considered for CbS, products must contain the same brand. View our documentation to review the CbS program requirements.
How does the publication / timing work for CbS devices compared to the primary product?
→ See our Publish Your Device guide on publication/timing.
Want to integrate your device(s) with SmartThings? Visit our Developer Center to get started and access Product Cloning and Certification by Similarity tools.
By tv2023
Hello
How can I set screen time limit for my kids on Samsung tv.I know there are parental controls to block apps etc but no way to set screen time limit.
I couldn't find any parental control apps either that control TV devices, are there any?
Smartthings app didn't work either to block TV. I can set scenes etc. but kids can just turn the TV back on.
Please help!!
By Mahesh Gadhe
As sometimes date and time for tizen tv is not correct so is there any way to set system date and time from app through code
By BGR
Samsung will take the stage in its home country later this week to unveil the Galaxy Z Fold 5 and Flip 5 foldables. This marks the first time the summer Unpacked event is being held at home rather than in an international market. It’s also the first time the mid-summer Unpacked press conference will take place in July rather than August or September.
I thought the arrival of Google’s Pixel Fold might have scared Samsung into moving up the launch event. But what if Samsung is really looking to deal with the iPhone ticking time bomb at home by looking to launch the new foldables as soon as possible?
Until this year, Samsung has had virtually no competition in the foldables space since the first Galaxy Fold. Samsung could take its time to upgrade the Fold and Flip each year without delivering massive redesigns. But Chinese vendors started putting pressure on Samsung in previous years. And some of those devices launched in Europe and other international markets in early 2023.
The Google Pixel Fold is perhaps the biggest threat to Samsung’s dominant position in the industry despite some of its obvious faults.
Samsung is responding to these threats with the kind of big Fold and Flip design updates we’ve been waiting for. The Fold 5 will be slimmer than before, thanks to a no-gap hinge. The Flip 5 will feature a large external display occupying almost the entire surface of one of the phone’s halves.
Google Pixel Fold smartphone unfolded. Image source: Jonathan S. Geller, BGR On top of that, Samsung set its Unpacked press event for July 26th, the earliest date ever. As a reminder, this Unpacked event used to be the home of the Galaxy Note series. And it used to happen in early September before Samsung detached it from the German IFA tradeshow. The reason Samsung went to early August was the iPhone’s early September launch which would routinely obliterate Note sales.
All that is to say that Samsung might be worried about increased competition in the foldables space. But the iPhone might be the real reason it’s focusing on the Korean market.
The big iPhone problem
Samsung might want to make an impression on a specific category of smartphone buyers in its home market. Per The Korea Herald, a new Gallup survey shows that young adults in the country prefer the iPhone overwhelmingly to a Samsung phone.
The study indicates that Samsung is the main smartphone vendor in Korea, with 69% of adults owning a Galaxy phone. Only 23% of respondents have an iPhone.
But younger millennials and Gen Z like the iPhone increasingly more than Samsung phones. In the 30-39 age group, 41% of respondents have an iPhone. The percentage goes to 60% in the 18-29 group.
Samsung vs. iPhone market share in Korea for different age groups. Image source: Gallup Korea via The Korea Herald This is a major problem for Samsung. These young adults are growing with the iPhone and the entire ecosystem of apps and hardware. Switching from iPhone to Android becomes increasingly difficult the more you use the products.
As a longtime iPhone user, I can attest to that. I’ve been on iPhone and Mac for over a decade, and there’s nothing to make me switch to a different combo. And I was in the 18-29 group when I started using Apple for my main computing needs.
The young adults who bought iPhone over Samsung cited Apple’s premium branding as one of the reasons. They’d buy the iPhone even if the same storage device is more expensive than the Galaxy S equivalent. For example, the 128GB iPhone 14 costs 1,250,000 won in the country, or $980. The Galaxy S23 is 100,000 won ($78) cheaper.
Various Galaxy Fold 4 and Flip 4 foldable phones. Image source: Samsung Apple Pay, which arrived in Korea earlier this year, is another factor that convinces young adults to buy iPhones.
The study also says that 85% of respondents say they are likely to stick with their current brand. That’s great for Samsung in the older groups. But if young adults stay with iPhone, we might be looking at decades of problems for Samsung. Especially if the teenage generation in Korea positions itself in favor of the iPhone. That wouldn’t be a surprise if their parents also use iPhones.
The unsung heroes in this survey are the older smartphone users who still have LG phones. LG is no longer making Android handsets, of course.
Samsung is apparently aware of the iPhone problem. The Herald says the Korean giant opened a flagship retail store in Gangnam last month, branding it a “playground for millennials and Gen Z.” The store is less than a kilometer away from Apple Gangnam store.
Don't Miss: Proton Pass finally lets you save credit card info with a new updateThe post The iPhone is a ticking time bomb in Samsung’s home market appeared first on BGR.
Samsung Art Store is the epitome of the digital-physical blend taking over today’s art experiences. It allows widely acclaimed galleries, museums and artists to showcase their masterpieces to users around the world by using The Frame’s immaculate digital display. Since its launch in 2017, Samsung Art Store allows for extraordinary, one-of-a-kind art selections to be accessible to consumers from the comfort of their own homes.
Stuart Franklin is an award-winning photographer who has traveled all over the world in pursuit of his work. The titles Franklin has held over the years vary from photographer to documentarian and art curator, with his work landing on the pages of newspapers, books, magazines and other media in between.
Over the years, Franklin’s work has gained considerable momentum and visibility — his work has earned a place in renowned publications around the world. Now, his work is featured on Samsung Art Store, introducing even more variety to the ever-growing art collection that is accessible through The Frame.
Samsung Newsroom sat down with Franklin to talk about his work and how he sees digital transformation taking the art world into new, unimaginable spaces.
▲ Stuart Franklin
Q: Briefly tell us about yourself, your work and the inspiration behind your photography.
I am a Magnum photographer, and I have been working in the industry for over 40 years. I am inspired by many things: light, form, the subject itself, often the overall idea behind a larger project. But these days I also enjoy drawing and painting as well.
I am currently working on a book about trees. 25 years ago, I published a book called The Time of Trees (1999), and I am now revisiting the subject in preparation for a new book in 2023.
Q: You began studying photography in 1976 and have made quite an impact since then. How has your photography evolved over time?
After studying drawing and painting, then photography, I began a career working for newspapers and news magazines. My stories were always people stories: in the news, street photography and portraits. This began to change during the 1990s when I began to focus more on landscape work — I worked on magazines, books or exhibition commissions and an exhibition for the National Galleries of Scotland.
Q: You are known for your wide array of photography styles. Could you elaborate more on your creative process?
My work has evolved over time. In the past, I worked mostly in news features or breaking news. I haven’t given that up: I recently did work on the Covid-19 pandemic in the U.K. But more and more I am focusing on landscape photography. Currently, I am interested in the relationship between nature and memory, so the conversation surrounds the relationship between elements in the landscape that spark a memory and something objectively interesting in the landscape itself.
Q: What is your favorite setting or location to take pictures?
Right now, forests. I have recently been working in the largest walnut forest in the world in Kyrgyzstan.
Q: Can you tell us specifically how advancements in technology and the emergence of digital art and platforms have changed or shaped your career?
Unusually, my work has moved full circle from working on color transparency film and black and white negative to digital color in about 2004 and now back to 80% film. I use my Samsung Galaxy S21 Ultra for about 90% of my digital color photography these days. Digital has many advantages, especially working in low light. But currently, I am working with film in black and white and digitally with the Galaxy S21 for color.
Backlighting and increased dynamic range are always an advantage with digital displays, but the disadvantage is often reduced image size. It is difficult to mix the two. Anything backlit in an exhibition will always stand out more than a silver gelatin print.
▲ “Caroline Islands (2000)”, Stuart Franklin
Q: Caroline Islands (2000) is one of your most popular photographs displayed on The Frame. Tell us briefly about this piece. Why do you think people are attracted to this image?
This landscape and these colors speak of somewhere remote, a get-away, an escape, somewhere quiet and undisturbed. In bustling urban life, all these qualities become desirable.
Q: A lot of your photography within the Art Store that gained popularity over the years involve nature. Can you tell us more about what your artistic intentions were for these photos?
I have always found solace in nature and in celebrating its beauty. The challenge is making inspiring places be as inspiring in a photograph. That usually involves choosing the right light and the best time of day to be out photographing so that the highlights are not too bright or the shadows too dark. Light — the quality of light — plays a huge role in how I think about photography.
▲ “Falls, Brazil (2000)”, Stuart Franklin
Q: Can you give us some background on this photo?
This photograph was taken in late 1999 on commission for the article titled Celebrations of Earth — published in January 2000 as the opening story of the new millennium. Due to the mist formed by the water thundering down the waterfall, the morning light stayed soft for quite a long time, which gave me enough chances to make several exposures from different vantage points. Also, Polaroid films that fit my camera were easy to buy back then to help me out in trials before making the actual exposures.
Q: Where do you see the future of photography art exhibitions heading? What are your thoughts about what’s to come?
I think there will always be an attraction in seeing the print as a three-dimensional object, as one sees a painting. However, I suspect in the future that the three dimensionality that we are used to experiencing in a gallery will be deliverable digitally and become widespread in time. The digital experience will expand in ways that we can barely imagine. There will be more virtual galleries and exhibitions. I feel sure of that, and that will make art more accessible to a wider range of people.
Q: Aside from the two photographs listed above, do you have any other recommended pieces for The Frame users?
I will always be one to flag my most recent work, so perhaps the work this year from Spain, Italy or Kyrgyzstan or the work I am about to do in November in Cambodia and Bali. But then I recommend the images from Bali that I took in 1999 for the Celebrations of Earth project — I still love those beautiful green rice fields. Then there is the work from Korea. Too much to choose from.
▲ “Rice Fields, Indonesia (2000)”, Stuart Franklin
To see more of Franklin’s photographs, head to the Samsung Art Store.
Similar Tagged Content
- 0 replies
- 5,561 views
