Smartwatches have become a part of our daily lives, combining functionality and style in one compact device. With Samsung's Watch Face Studio (WFS), designers can create unique watch faces that are customized to their requirements. Dynamic weather features, which display real-time updates and forecasts on the watch face, are particularly appealing.
This article covers WFS’s weather features, their uses, and how to create useful weather-themed watch faces. You can create a watch face using weather data as art.
This article introduces the following weather features which enhance watch face design:
  1. Weather forecast
  2. The last time the weather was updated in ICU format
  3. Weather tags
You can follow the examples in this article by downloading the sample project from here.
Forecast for the next few hours and days
Weather information becomes more valuable when presented in a way that is easy to read at a glance. Using weather tags, WFS enables you to easily incorporate forecasts for the coming hours and days.
Hourly forecast
The forecastHours(index, text) tag can be used to show hourly weather updates. One of the two pieces of information that the forecastHours tag collects is an index that takes a number starting at 1 for the following hour. Thus, by setting the index, you can set the data for the next few hours.
The text part uses five distinct weather tags:
• Temperature
• Time of day
• Weather condition
• Weather condition name
• Weather data available
Use the forecastHours tag with the weather condition, time, and temperature to offer users a short-term forecast of what to expect throughout the day. Tiny weather icons (like Sunny: ☀️, Rainy: 🌧️, and Snow: ❄️) can be used as bitmaps portraying the current weather conditions and the corresponding temperatures.
Forecast hours for icon
You can set the weather icon for the upcoming hour by following these steps:
  1. Create a text component.
  2. Use this forecast tag on the text: forecastHours (1, "COND")
  3. Choose the Bitmap Font to use icons for the forecastHours ().
  4. Select images for the appropriate weather conditions.
5. Set the font size to 40.
undefined
undefined
undefined
undefined
Figure 1: Setting the font size
undefined
  1. Include 10-15 on the CUSTOM tab since weather condition has values up to 15.
undefined
undefined
undefined
undefined
Figure 2: Bitmap font setting
undefined
Forecast hours for temperature
You can now adjust the temperature by using the forecastHours() tag. You may display the temperature (positive or negative) for the upcoming hour and the temperature unit in degrees by following these steps:
  1. Consider a text element.
  2. To display the temperature in degrees, use forecastHours(1,"TEM")°
  3. Choose the temperature unit (([WTHR_TEM_UNIT] == 1)? "C": "F")
    The full tag expression looks like this:
    (forecastHours(1, "TEM"))°(([WTHR_TEM_UNIT] == 1)? "C": "F"))
    To display the weather forecast for the next hour, just change the index value to 2.
Availability of weather data
For every forecast tag, you need to check if the data is available with this tag: (forecastHours(X, "IS_AVAIL")).
In the sample project, for every forecast group, the corresponding weather tag is used for checking its availability. The following tag expression is used for the next hour’s forecast:
((forecastHours(1, "IS_AVAIL")) - 1) * 100
undefined
undefined
undefined
undefined
Figure 3: Tag expression for checking availability of weather data
undefined
Daily forecast
You can incorporate daily weather forecasts into watch face designs using the forecastDays() tag. Customized indices (for example, 1 for tomorrow) make it simple to portray multi-day weather trends. WFS lets you show the weather conditions for a certain day, including high and low temperatures using forecastDays(index, "TEM_HIGH") for highest temperature and forecastDays(index, "TEM_LOW") for lowest temperature.
The later parts of the sample project show the weather predictions for tomorrow.
WFS uses the forecastDays(1,"TEM_HIGH") tag to show the temperature for the following day’s high and forecastDays(1,"TEM_LOW") tag for the next day’s low.
For the high and low temperatures tomorrow, use the following tag expression:
(forecastDays(1,"TEM_HIGH"))° ~ (forecastDays(1,"TEM_LOW"))°(([WTHR_TEM_UNIT] == 1)? "C": "F")
You can apply a similar tag expression for the forecast for the days after tomorrow by changing the index value.
Last weather update (ICU format)
This watch face example incorporates the most current update time to reassure customers that the weather information is recent. Weather data should be updated often to remain accurate.
WFS offers the most recent weather update in the ICU format. To add the most recent weather update time in ICU format, follow these steps:
  1. From the component list, get the ICU date and time.
undefined
undefined
undefined
undefined
Figure 4: ICU date and time
undefined
  1. To customize the ICU date and time, select the PROPERTIES tab.
  2. Choose the ICU Format as HH: MM from the DATE AND TIME section.
  3. Set the Local Calendar to Gregorian and the Time Zone to Sync with Device.
  4. Select Last Updated Time (Weather) as the Time Source.
undefined
undefined
undefined
undefined
Figure 5: Date and Time
undefined
Other weather tags
Current weather condition for icon
You can use the bitmap font for the current weather condition since it is already prepared for forecastHours(). Use the [WTHR_COND] tag, which provides the current weather, and choose bitmap as the font setting.
Current temperature
Use the [WTHR_TEM] tag to show the current temperature. The current temperature is obtained with the following tag expression, which also sets the temperature unit:
[WTHR_TEM]°(([WTHR_TEM_UNIT] == 1)? "C": "F")
Today’s highest and lowest temperatures
You can display the highest and lowest temperatures of the day by using the tags [WTHR_DAY_TEM_HIGH]) for the highest temperature and [WTHR_DAY_TEM_LOW] for the lowest temperature. The highest and lowest temperatures for today are listed below, based on the forecastDays() tag expression for the highest and lowest temperatures for the following day:
([WTHR_DAY_TEM_HIGH])° ~ ([WTHR_DAY_TEM_LOW])°(([WTHR_TEM_UNIT] == 1)? "C": "F")
Summary
Smartwatches offering weather forecasts are useful and engaging. With WFS, designers can use advanced tags like forecastDays(), forecastHours(), and last update time to deliver real-time weather updates, daily forecasts, and information such as high and low temperatures. Because they provide information at a glance, smartwatch faces are practical and attractive.
If you have questions or need help with the information presented in this article, you can share your queries on the Samsung Developers Forum. You can also contact us directly for more specialized support through the Samsung Developer Support Portal.
      “Samsung’s QLED technology played a crucial role in bringing quantum dots to the level of recognition needed for the Nobel Prize in Chemistry.”
      Quantum dots have been at the forefront of display innovation over the past decade, delivering some of the most accurate color reproduction among existing materials. In 2015, Samsung Electronics paved the way for the commercialization of quantum dots with the launch of SUHD TVs — a breakthrough that moved beyond the use of cadmium (Cd), a heavy metal traditionally utilized in quantum dot synthesis, by introducing the world’s first no-cadmium quantum dot technology.
      The academic world took notice. The successful commercialization of cadmium-free quantum dot TVs not only set a new direction for research and development but also played a pivotal role in the awarding of the 2023 Nobel Prize in Chemistry for the discovery and synthesis of quantum dots.
      Following Part 1, Samsung Newsroom uncovers how Samsung has contributed to academia through groundbreaking advances in material innovation.
      ▲ (From left) Taeghwan Hyeon, Doh Chang Lee and Sanghyun Sohn
      Why Cadmium Was the Starting Point for Quantum Dot Research
      “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Quantum dots began attracting scientific interest in the 1980s when Aleksey Yekimov, former Chief Scientist at Nanocrystals Technology Inc., and Louis E. Brus, a professor emeritus in the Department of Chemistry at Columbia University, each published their researches on the quantum confinement effect and the size-dependent optical properties of quantum dots.
      Momentum accelerated in 1993 when Moungi Bawendi, a professor in the Department of Chemistry at the Massachusetts Institute of Technology (MIT), developed a reliable method for synthesizing quantum dots. In 2001, Taeghwan Hyeon, a distinguished professor in the Department of Chemical and Biological Engineering at Seoul National University (SNU), invented the “heat-up process” — a technique for producing uniform nanoparticles without the need for size-selective separation. In 2004, Hyeon published a scalable production method in the academic journal Nature Materials — a discovery widely regarded as a potential game changer in the industry.
      However, these efforts did not immediately lead to commercialization. At the time, quantum dots relied heavily on cadmium(Cd) as a core material — a substance known to be harmful to humans and designated as a restricted material under the European Union’s Restriction of Hazardous Substances (RoHS) Directive.
      “Currently, the only materials capable of reliably producing quantum dots are cadmium selenide (CdSe) and indium phosphide (InP),” explained Hyeon. “Cadmium selenide, the conventional quantum dot material, is a compound of group II and group VI elements, while indium phosphide is formed from group III and group V elements. Synthesizing quantum dots from group II and VI elements is relatively straightforward, but combining group III and V elements is chemically much more complex.”
      ▲ A comparison of cadmium-based quantum dots with ionic bonds and indium-based quantum dots with covalent bonds
      Cadmium, an element with two valence electrons, forms strong ionic bonds1 with elements like selenium (Se), sulfur (S) and tellurium (Te) — each of which has six valence electrons. These combinations result in stable semiconductors, known as II–VI semiconductors, materials that have long been favored in research for their ability to produce high-quality nanocrystals even at relatively low temperatures. As a result, the use of cadmium in quantum dot synthesis was considered an academic standard for many years.
      In contrast, indium (In) — an alternative to cadmium with three valence electrons — forms covalent bonds2 with elements such as phosphorus (P), which has five valence electrons. Covalent bonds are generally less stable than ionic bonds and have a directional nature, increasing the likelihood of defects during nanocrystal synthesis. These characteristics have made indium a challenging material to work with in both research and mass production.
      “It is difficult to achieve high crystallinity in quantum dots made from indium phosphide,” Lee noted. “A complex and demanding synthesis process is required to meet the quality standards necessary for commercialization.”
      No Compromise – From Breakthrough to Mass Production
      “There is simply no room for compromise when it comes to consumer safety.”
      Samsung, however, took a different approach.
      “We had been researching and developing quantum dot technology since 2001,” said Sanghyun Sohn, Head of Advanced Display Lab, Visual Display (VD) Business at Samsung Electronics. “But early on, we determined that cadmium — which is harmful to the human body — was not suitable for commercialization. While regulations in some countries technically allow up to 100 parts per million (ppm) of cadmium in electronic products, Samsung adopted a zero-cadmium policy from the start. No cadmium, no compromise — that was our strategy. There is simply no room for compromise when it comes to consumer safety.”
      Samsung’s long-standing commitment to its principle of “No Compromise on Safety” came to the forefront in 2014 when the company successfully developed the world’s first no-cadmium quantum dot material. To ensure both durability and image quality, Samsung introduced a triple-layer protective coating technology that shields indium phosphide nanoparticles from external factors such as oxygen and light. The following year, Samsung launched the world’s first commercial SUHD TV with no-cadmium quantum dots — a paradigm shift in the display industry and the culmination of research efforts that began in the early 2000s.
      “Indium phosphide-based quantum dots are inherently unstable and more difficult to synthesize compared to their cadmium-based counterparts, initially achieving only about 80% of the performance of cadmium-based quantum dots,” said Sohn. “However, through an intensive development process at the Samsung Advanced Institute of Technology (SAIT), we successfully raised performance to 100% and ensured reliability for more than 10 years.”
      ▲ The three components of quantum dots
      Quantum dots found in Samsung QLEDs are composed of three key components — a core, where light is emitted; a shell, which protects the core and stabilizes its structure; and a ligand, a polymer coating that enhances oxidation stability outside the shell. The essence of quantum dot technology lies in the seamless integration of these three elements, an advanced industrial process that spans from material acquisition and synthesis to mass production and the filing of numerous patents.
      “None of the three components — core, shell or ligand can be overlooked,” added Lee. “Samsung’s technology for indium phosphide synthesis is outstanding.”
      “Developing a technology in the lab is a challenge in itself, but commercialization requires an entirely different level of effort to ensure product stability and consistent color quality,” said Hyeon. “I was truly impressed that Samsung succeeded in commercializing a no-cadmium quantum dot display product.”
      Setting the Quantum Dot Standard
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs.”
      The optical properties of quantum dots are being applied to a wide range of fields, including solar cells, medicine and quantum computing. However, the quantum dot display remains the most actively researched and widely commercialized application to date — with Samsung emerging as a pioneer.
      Building on years of foundational research and the introduction of its SUHD TVs, Samsung launched its QLED TVs in 2017 and set a new standard for premium displays. In 2022, the company pushed innovation further with the debut of QD-OLED TVs — the world’s first display to combine quantum dots with an OLED structure.
      ▲ A comparison of LCD, QLED and QD-OLED structures
      QD-OLED is a next-generation display technology that integrates quantum dots into the self-emissive structure of OLED. This approach enables faster response times, deeper blacks and higher contrast ratios. Samsung’s QD-OLED was awarded Display of the Year in 2023 by the Society for Information Display (SID), the world’s largest organization dedicated to display technologies.
      “Samsung has not only led the market with its indium phosphide-based quantum dot TVs but also remains the only company to have successfully integrated and commercialized quantum dots in OLEDs,” said Sohn. “By leveraging our leadership in quantum dot technology, we will continue to lead the future of display innovation.”
      “Research trends in the academic community shifted noticeably before and after the release of Samsung’s quantum dot TVs,” said Doh Chang Lee, a professor in the Department of Chemical and Biomolecular Engineering at the Korea Advanced Institute of Science and Technology (KAIST). “Since its launch, discussions have increasingly focused on practical applications rather than the materials themselves, reflecting the potential for real-world implementation through display technologies.”
      “There have been many attempts to apply quantum dots in various fields including photocatalysis,” he added. “But these efforts remain in the early stages compared to their use in displays.”
      Hyeon also noted that the successful commercialization of Samsung’s quantum dot TVs helped pave the way for Bawendi, Brus and Yekimov to receive the 2023 Nobel Prize in Chemistry.
      “One of the most important criteria for the Nobel Prize is the extent to which a technology has contributed to humanity through commercialization,” he said. “Samsung’s QLED represents one of the most significant achievements in nanotechnology. Without its commercialization, it would have been difficult for quantum dots to earn Nobel recognition.”
      Samsung’s Vision for Tomorrow’s Displays
      Since the launch of its QLED TVs, Samsung has accelerated the growth of quantum dot technology in both industry and academia. When asked about the future of quantum dot displays, the experts shared their insights on what lies ahead.
      “As a next-generation technology, we are currently exploring self-emissive quantum dots,” said Sohn. “Until now, quantum dots have relied on external light source to express red and green. Going forward, we aim to develop quantum dots that emit light independently through electroluminescence — producing all three primary colors by injecting electrical energy. We are also working on the development of blue quantum dots.”
      “As electroluminescent materials make it possible to reduce the size of device components, we’ll be able to achieve the high resolution, efficiency and brightness required for virtual and augmented reality applications,” said Lee, predicting a major transformation in the future of displays.
      “A good display is one the viewer doesn’t even recognize as a display,” said Sohn. “The ultimate goal is to deliver an experience that feels indistinguishable from reality. As a leader in quantum dot display innovation, we will proudly continue to move forward.”
      With its continued leadership and bold technological vision, Samsung is shaping the future of displays and rewriting what’s possible with quantum dots.
      1 An ionic bond is a chemical bond formed when electrons are transferred between atoms, creating ions that are held together by electrical attraction.
      2 A covalent bond is a chemical bond in which two atoms share electrons.
      Samsung Electronics today announced a new partnership with FlexIt, a health and wellness solution that makes exercise more convenient and accessible. Starting this month,1 FlexIt will bring personal trainer-based fitness content to Samsung Smart TV users through the new lifestyle hub Samsung Daily+2 on Samsung Tizen OS.
      “Wellness should be central to our routines, so building healthy habits through Samsung Daily+ makes it convenient to incorporate health and wellness into all different aspects of daily life,” said Demian Hyun, Vice President and Head of the Experience Planning Group of Visual Display Business at Samsung Electronics. “This new partnership underscores Samsung’s commitment as the leader in the global display industry to promoting thoughtful, interconnected health experiences aimed at bettering the lives of consumers.”
      On the FlexIt app’s online portal, users can find, book and pay for exclusive one-on-one virtual fitness sessions directly on their TVs. With a camera connected — whether it be via a supported webcam3 or a smartphone — virtual health professionals4 provide real-time feedback, adjust workouts and offer form modifications to foster a supportive, safe and effective workout environment.
      The FlexIt app helps users approach their health in a more holistic way; in addition to workout content, FlexIt offers nutrition training, low-impact wellness activities like meditation and yoga, and physical and occupational therapy. By working virtually with a trainer who understands their personal fitness journey and wellness goals, users craft an attainable routine that suits their needs and lifestyle, all from the comfort of their home or any other location with a connected device.
      By housing services such as FlexIt, Samsung Daily+ is paving the way for the future of virtual health and wellness experiences through its convenience and accessibility to build productive and convenient daily routines. Samsung Daily+ serves as a new lifestyle hub for Smart TV users, allowing them to conveniently enjoy a wide range of premium lifestyle services and features — such as home fitness, telehealth services, video calls and more — using one single interface.
      “Through the innovative FlexIt app for Samsung, we’re furthering our commitment to making fitness more accessible than ever. By delivering personalized, one-on-one immersive training experiences directly to your living room, we’re extending our reach to a broader audience, empowering individuals to achieve their wellness goals with ease and convenience,” said Austin Cohen, FlexIt’s Founder and CEO.
      During CES® 2024, Samsung gave consumers an early look at Samsung Daily+ and the FlexIt app on its 2024 Neo QLED 8K. Richard Friedman, FlexIt’s Senior Vice President of Technology, joined the Samsung team in Las Vegas to showcase how the FlexIt app integrates with Samsung TVs. Samsung Daily+ is also a 2024 CES Innovation Awards Honoree, having been recognized as a unique smart home service with an open ecosystem that integrates third-party services.
      For more information on health offerings on Samsung’s TV lineup, visit Samsung.com.
      About FlexIt
      FlexIt has revolutionized the fitness and wellness industry through its innovative, cutting-edge technology, offering a comprehensive approach to holistic well-being for consumers and enterprises. Its core solution centers around live, one-on-one, two-way personal health and wellness sessions with fitness and wellness experts, accessible through both web and app platforms. FlexIt’s platform goes beyond just fitness training, embracing holistic well-being through nutrition coaching (led by registered nutritionists with a focus on weight loss), low-impact wellness activities (yoga, meditation, stretching and dance), health coaching, and physical and occupational therapy (covering preventive, pre/post-natal, senior and recovery), offering 28 health modalities on the platform.
      Our comprehensive and innovative approach has earned us recognition within the industry. FlexIt has been selected for the Best Budget-Friendly Coaching App of 2023 by Women’s Health, the Best Personal Trainer Apps of 2023 by Forbes, and the Best Fitness Apps in 2023 by Oprah Daily and has been awarded by Men’s Health, Inc. 5000, US News & World Report, among many others.
      For media inquiries, please contact:
      [email protected]
      1 Availability varies by model and region. The FlexIt app will be available through Samsung Daily+ on all 2024 TV models: Neo QLED 8K, 4K, OLED, UHD (above DU7000) and The Frame. OS upgrade is scheduled to be provided for select 2023 TV models during the second half of 2024. 2022 and 2021 TV model users can download the FlexIt app through the app store.
      2 Starting this year, Samsung Daily+, a hub for lifestyle experiences, provides a wide range of services and features — from personal training and telehealth to video calls and remote PC solutions — in one single interface. With Samsung TVs at the center of the home, users can enjoy the benefits of the latest innovations and seamless connectivity between devices in their day-to-day lives.
      3 Logitech Webcam (C930e, C922 PRO STREAM WEBCAM, C925E, C920s Pro HD Webcam, HD Pro Webcam C920, C920-C, C930c, HD Pro Webcam C920, StreamCam), Samsung (SC-FD100B)
      4 English- and Spanish-speaking FlexIt health professionals and trainers
